Hey guys...
Had my car on the dyno yesterday, pulled 160.9 rwkw
Showed the sheet to a mate of mine and he said that the air fuel ratios are a bit out of wack.
He recons a boost controler will fix this issue and ill br able to get more power out of it
Just wanting to know what u guys think about it and what some of your recomendations would be
Car is a stock R34 GTT
Cheers mick
https://www.sau.com.au/forums/topic/228935-had-dyno-run-and-need-an-opinion/
Well for a state, your mate - dont listen to him :D
More boost is likely more than not, to flip the ECU out and then you'll have a massive power dip around 4000-5000rpm.
What you need is a band-air interceptor (S-AFC etc) or a full ECU (PowerFC etc), thats the only way to solve that problem
SAFC to fix the AFRs or come down to Sydney and have Toshi remap your stock ECU (you can find him on the forums here).
You're running very rich at the moment .. safe AFRs are 11.5:1 at the top end and you're at less than 10:1
I'm surprised you're making that much power with a stocker that's running so rich ... I was making around 150rwkw with a stocker + turbo back exhaust, now at 190rwkw with turbo back and boost controller at 11psi and Toshi's ecu remap.
If you're going to get a boost controller, get it before any tune so that the ecu can be tuned with the new higher boost ... otherwise you'll pay twice.
Edited by Delta Force
Hi Delta Force.
EJD001
R34 can not boosted up more than around 12psi.
Because ignition timing will retard around 12psi.
Its same R33.
Also R34 boosted up under 12psi , it will ping at 3600-4400rpm when the accelerator is put down on street.
Because R34 ignition map is 3600-4400rpm very hi ignition timing for Australia fuel.(maybe 100 octane fuel is OK)
You need remap or PFC(need tune).
lol @ looks normal..
no it doesnt lol thats really really fkn rich.. a stock computer wil never flatline a dyno. thats rich as f**k, 10:1 is fkn super super rich and thats considering that it flatlines there.. who really knows how rich its running
get it tuned champ and ull enjoy more power and better fuel economy while thrashin :rofl:
fuel economy is not too bad... did a run from gosford to bathurst and back and used one and a bit tanks. but i got 510km before having to fill... ofcourse hghway driving is the big factor there!
So u think im better off just getting a PFC or getting the standard ecu looked at.
In the future i am going to go for larger numbers, thats y im leaning towards a PFC
Edited by EJD001
My R34 made 161rwkw with a cat back exhuast and around 11psi. Once again operator said she was running very rich
I had never noticed the flat spot. Until recently, feels like a massive second kick somewhere near 6 and she starts going again! :rofl: stupid factory comp. Im definitely getting the flat spot now.
Its possible the boost is running mine too rich and probably robbing some power.
Here is my graph. Because it was a simple cheap power run the print out doesnt include the afr etc.
Edited by Granthem
i cant work out y im getting such good figures..
Like grant, he has upped the boost and put on a exhaust and its making the same power as my car, which i havent upped the boost or done any mods to!
Cars are so fun sometimes!
Yeh dynos change from place to place.
Easiest way is to track it.
Currently my car has run a best of 14.0 and more importantly at a best of 99mph. So i guess its pretty close to 160rwkw in a chunker of a car to get that top end speed.
Throw yours on the strip and find out what she pulls. Without the boost increase, my car was running 92-93mph. If your cracking much more then that, your lucky and got a freak of an engine :rofl:
now looking into a PFC...
Should i be looking at a second hand one or brand new.... is there much that can go wrong with a second hand unt?
Price will be the big difference aswell i would think!
Thanks to everyone for their input so far...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
