Modifying factory GTR exhaust manifolds.
95 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I just did this to mine....matched ported the inlets and turbo flanges..and even done the metal HKS gaskets...was easy when taking the turbos off the carbon deposit that was left on the manifolds and gaskets pretty much outlined it all.
I used a dremal with a tungston carbide tip that was alot better that the grinding stones that you can get from supercheap, which are no use at all.
Found a store at minto, that sell only abrasives..got the proper grinding stones and the tungston tip from there...$3 for stones...and $15 for the tip.....the stones last a very long time and are the proper ones to get.3mm size shanks.
too bad only just read this, i have just finished putting back my turbos. could have taken some pics.
  • Replies 64
Have you got the details for the shop at Minto? I should get some of those tips for future use, but also other people that might be reading this thread could make use of the info. Notably the 2 people that voted with the gung ho option :D
It is good to see that other people have already ported their manifolds. Makes me feel like less of a leper. Or if I still am, I'll just join you other DIY lepers in the colony.
DIY leper all the way.
Add that to the list, Rewiring the cluster, 044 intank with custom machined fittings, fitting the turbos completely opposite to what the service manual says, coil pack repairs, etc..
If you use common sense, think about what you are doing, and are prepared to replace any parts that you break along the way you can't go wrong.
Only things I have gotten others to do is fit the suspension (pain and it needs to be adjusted then), and to fit the clutch and tune it. I really don't like the idea of that heavy gearbox under the car in my shed.. bad enough when I was playing with the old single rail and t5's.
we run standard r32 manifolds too, just cleaned up also.
we actually lost response and low down power with some other after market manifolds.
Edited by giant
When you say cleaned up, was it the same sort of process as what people have been posting on this thread?
bump this thread, good read and useful info... also looking into doing the same mod to my manifolds, i have a spare set that came with my -7's and would like to get the ported for more flow......
IMO i think its a win win situation porting the manifolds, as you are essentially removing any areas of teh metal which will cause turbulence, thus this should create a smooth interrupted exhaust velocity speed directed directly into the turbo........
i read in a book somewhere about air velocity speed that this can also work,
air speed can be accelerated bu using a unique design on say a pipe....
lets say we used a 45mm opening to get air thru a pipe, now, say that pipe is a sweeping bend like most manifolds, and this pipe so to speak was something like300mm long, say if we smoothly tapered down to like 42mm half way thru this pipe and opened up again to 45mm on the exit of the pipe, the air speed would be faster in a forced environment, if this is true, you could essentially get the turbos onto boost easier and also have no restriction up to at all...
if this is true, which i read in a book years ago, i wish i could find it, would it be beneficial to open up the ports on the manifold where it bolts to the head say afew mm to compensate for the larger port size in the head,, smoothly taper down to the standard size, ( cleaned up abit) then once again opened up to flow smoothly into the turbo housing like you boys have been doing so far????
just a thought
Edited by den001
This completely works. When my stock rear turbo died and I was low on cash so I decided to just replace with another stock turbo. Whilst everything was apart I opened up both the manifold, and the turbo slightly, and once it was back on the road, I was hitting full boost almost 1000rpm earlier. Although it is true about faster air flow when there is a thinner section of pipework ( a venturi) for a turbo to spool well, it requires a greater volume of air to pass by the exhaust wheel. The bigger the path for the air, the better the flow, and the earlier the boost comes on.
Having said that, it would have been a good idea to either block the exhaust side of the turbo from any shavings, or take it apart and blow the shavings out before refitting to the car. After 2 months of having the car on the road, the rear turbo let go again and was found to have shavings blocking the oil return to the engine.... oops
GT-SS going in now though, I might be more careful when matching these turbos to the manifold
I've posted this before in my T618Z 10cm2 vrs HKS GTRS thread....search function isn't working for me though.
We flow tested some Chinese stainless rb26 manifolds and the flowed twice as much as the std cast items. We then spent 6 hours porting the cast manifolds-taking the bumps clean off the head side, opening right up the turbo collector paying attention to the wall thickness with some pinches. The greatest increase was had from the short turn....huge amounts can be taken out. They were reflowed and came up within a few cfm of the stainless items. With the energy retaining benefits of cast over stainless, I know what I will be using. The runner diameter was not increased at all.
Matt
  • 1 month later...
I had a crack at porting out my turbo flanges on the exhaust manifolds. I didn't really do much other than remove the "lip" that is on there. Matched it up to the HKS 2530's that will be going on there. Probably increased the surface area of teh flange by about 15%?
Used an air dye grinder and tungsten carbide tip as well - went through it heaps easy and way neater than I thought.
Pics:
Edited by dorifticon
Oh something I found a few weeks ago but forgot to mention in here, it seems that there is a reason to be doing this mod. Looking at the pic that I've attached, the N1 manifold seems to simply be the factory manifold with the same bits ground out. Pic found here - http://gtrusa.blogspot.com/2007/11/rb26det...ths-truths.html
Also I'm wondering if the people who I have heard complain that the 2530's are laggy on GTR's are running the stock manifolds? (this includes the person I bought them from, I think he changed to GT-SS's). Because I find it hard to tell that my 2530's are any laggier than the stock turbos. There are times where I think they are even more responsive than stock. Some of that would be due to the ball bearings vs plain bearings, but I also think the ported/matched exhaust manifolds would have a lot to do with it.
Anyway looking at this photo, I think that if anyone is thinking of buying N1 manifolds, don't pay any more than you would for a good porting job because they seem to be exactly the same thing aside from the size of the turbo flange hole.
  • 8 months later...
this thread is a very good read (8 month thread resurrection) - i was searching for 'stock matched vs aftermarket' & this answers my question :)
im at the juncture where i need decide on which way to go & it seems that port matched/extrude honed stock manifolds is the answer for my new setup...
if its good enough for Mark Berry's racecar & the others on this thread (BoostR, dirtgarage etc) well that is good enough for me :P
there would be nothing worse than cracking a set of expensive tubes (although probably not as common as i think) THEN having to replace whilst in the engine bay :);):huh::)
I am in 2 minds at the moment. about to bolt on a set of HKS GT-SS, tomei expreme manifolds and tomei dumps to my heavily ported head.
I used the tomei manifolds on my last set-up which was very similar. it had ported head (a bit milder than this one though), tomei manifolds, HKS GT-SS and tomei dumps. it was very responsive. the path through the manis is very direct and they are very open so the exhaust gas is hitting the turbine very hard. the turbine entry on THE GT-SS needs some opening up itself. and you can see the turbo mount flange on the tomei manifolds is huge next to a stock one.
for this engine I'm thinking of trying stock manifodls ported out. but on the other hand the tomei mani's are a work of art and seem to work pretty well.
Up to a certain power level, the basic engineering (shape and cross sectional area) should flow heaps, with the restrictions multiplying at each poorly matched junction (ie. head to manifold, manifold to turbo, turbo to dump). At the factory rated power level it wouldn’t be a problem, but proper finishing work = “free” power due to efficiency gains.
I reckon you’re in the box seat Richard, with that Tomei gear at your disposal, but the guys who are cost-limited surely wouldn’t be too far behind with a set of properly finished stock cast items? Be interesting to see which way you go.
I like the general way GTRSean went with port matching, but going off pics maybe needed some more work around the short side radius at the collector? Those sharp edges looked a bit abrupt.
It’s great to see guys getting their hands dirty, learning what makes their car go, and sharing the experience.
beer baron - if i had a set of aftermarket tubes & they have been fine i'd stick with them!
my stock items have been port matched & now i need to find someone who can extrude hone them, i spoke to john from UAS who no longer offers this service...is there anyone out there who can point me in the right direction for extrude honing?
if it helps, i live in sydney :blink:
if it helps, i live in sydney :ninja:
I just remembered the guy who did extrude honing in Sydney had stuff for sale on ebay, maybe he has closed up. I bought a machine a few years ago but the cost to run one and the jigs you needed turned me off it so I sold it again.
Here's a graph of your head Marko with the port and no manifold, port and std manifold and port with the runner and outlet opened up, not a massive difference with the porting, there is some though. The manifolds are a definite restriction though as you can see in the graph. I'd like to test those 6 boost twin manifolds, they really look the goods.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
