Im just about to get an exhaust put in from the turbo back... car is stock ATM
my question is .. will i need to change the dump pipe once i upgrade my turbo .. i will be upgrading to the GTRS Bolt on kit
cheers
Usually you do change the dump pipes when you have a new turbo installed.
You are upgrading to get more force induction right... Hence turbo upgrade, well you will need to get bigger dump pipes to allow better flow for the exhaust.
Then upgrade your, front pipes and install a high flow cat.
BTW I see you listen to Pantera... Yeeeha! Another Cowboy from Hell to join the Skyline enthusiasum. :D
while on the topic of dump pipes, GTR
i have some that are 2.5" and 1.5" wastegate pipe that vents back just befor the flange, got front pipes 2.5" to 3" decat and 3.5" back now
i am looking at cutting the wastegate pipe about halfway and gringind and blocking the return then bending up a 2" pipe (screamer pipe) and running them both to the bottem bend of the front pipe straight on the ground, its this worth it? what are some ppls opinions some told me to just run it down and vent it in just before the cat. im not worried about the noise factor.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
