Hey everyone,
I've tried a quick search on this subject but there hasnt been much clear cut info that i've found. The z32 is the more common choice, but for the people chasing bigger power again in a single afm setup, wheres the brick wall for the q45.
I've heard that they read more and less than the z32, and some say it can read 500rwkws (which i find hard to beleive) so i'm not sure whats the real deal is. I've also read that the q45 can cause some problems at idle since its so big on a 2.5L, so im abit unsure on this.
So who out there actually has a q45 wired into their car, and how is it like to drive? Have there been any problems? What sort of power are you making on it and importantly at those power levels what was the afm voltage at? Also who has actually maxed the q45 out and what power was it making/boost pushing?
I've personally seen the stock afm run out of puff at the 200rwkw range, and the z32 gives up a bit past 300rwkw's, but the q45 is something i've always wondered about
https://www.sau.com.au/forums/topic/230570-q45-afm-limit/
im not normally a kw person, i would of thought 450rwhp would see a z32 maxing (abliet thats more than 300rwkws, just getting lazy with the conversions)
anyhoo, not really interested in the z32 side of things, just what the q45 is capable of ;)
https://www.sau.com.au/forums/topic/230570-q45-afm-limit/#findComment-4051630
The Q45 AFM will max out way before the Z32 one... Check out www.nicoclub.com they have a whole forum dedicated to the VH45. I've been hanging around there a lot since I'm sticking a turbo VH45 into a Z32... ;):)
https://www.sau.com.au/forums/topic/230570-q45-afm-limit/#findComment-4051725
it can vary, there are ones with large resolution and some without. mate of mine has one of the low ones, tops out just below 5000rpm (GT35R, RB30DET). if you get one of the 'high' reading ones i think its prettys imilar to a Z32, but just stick with the Z32 as its a known thing
https://www.sau.com.au/forums/topic/230570-q45-afm-limit/#findComment-4052082
is there a way to see which q45 is high or low resolution without plugging it in?
https://www.sau.com.au/forums/topic/230570-q45-afm-limit/#findComment-4052202
560 rwhp - Std Q45
Have just removed the internals of the Q45 and fitted it to a 4 inch intake - aiming for 600 rwhp with this set up
:cool:
so would you have a high resolution q45 afm then? did it max out right on 560rwhp or was it a a while before that?
https://www.sau.com.au/forums/topic/230570-q45-afm-limit/#findComment-4052208
This is where i start to get in the "flip a coin" state,
once my motor is built i'll be aiming for around 450awhp on the street and about 500+awhp when on race gas (not very often), but im not sure to run a powerfc and use a q45 afm or to use another ecu with a map sensor. Preferably i would like to use a afm, but it seems that 500awhp will max out one, and i didnt really want to run a y pipe in the intake and half the afm values mainly because i would like it neat.
if the q45 isnt up to the task, maybe i should just go map :(
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/230570-q45-afm-limit/#findComment-4052497
  • 1 month later...
thats what the gtrs have from factory, but there isnt two afm inputs for the normal gtst's gt-t's. The only thing i've seen that is simular to what you're mentioning is running one afm, but use a ypipe in the intake so it only get half the air. When tuning you then halve the afm values and you've effectively doubled the reading power of the afm.
I just dont like the idea of that because its not neat imo and it can be a bit rough for daily driving (cruising rpm)
https://www.sau.com.au/forums/topic/230570-q45-afm-limit/#findComment-4149069
  • 2 months later...
hello
this has been covered a lot in the past
to date, we have see no evidence of there being two versions of the Q45 - a high and a low - so its is believed there is only one version, yellow label, 3.5", 3 wire AFM
but we have known some users fly past 350rwkw with a Q45 and some hit a "wall" around 250rwkw+ish with the Q45's
so i suspect theres two outcomes
1) there are two versions
2) there is only one version and someone is picking up the wrong model AFM, or there is another cause for maxing the AFM
either way if you want near 350rwkw go for Z32
https://www.sau.com.au/forums/topic/230570-q45-afm-limit/#findComment-4281113
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
