The other day my car started to splutter while driving and i couldnt get power out of it to drive it up my street.
So today i swapped over the fuel pump to a new walbro pump to see if thats was the problem but it hasnt fixed it.
The car at idle is not stable at all it hunts and stalls if it isnt revved at all, it is also blowing some smoke aswell.
I had the turbos replaced a couple of months ago and i havent had any problems until now.
Does anyone have any idea what could be the problem because i really need my car running 100%.
try take if your cooler pipework, if there is oil one of them then one of your turbos is possibly stuffed. if not you need to do a compression test to see if it is your engine. i think each pot should be around 150 psi but not sure, anyone verify that?
Edited by Pal
ide also suggest looking at the afm. also wouldnt hurt to take a look at ur coilpacks/plugs. a failing coil, would make the car idle poorly (sound like a wrx, as its runing on 5 cylinders) and would make it run like a dog with 3 legs.
+1 for the coilpacks!
My car was/is doing almost exactly the same thing. Blowing out a bit of black smoke and smelling like fuel when you start it up? My car is at the mechanics now and waiting for a new set of coilpacks to come in. It was fouling the plugs and make the car sound and go like a tractor. Only like 30kmh, misfiring badly, lucky it happened on my street coming home.
+another1
My car is doing the exact thing :D
Got another set in the mail.
Just pulled my coil packs off and they look fine. Im glad considering they are splitfires and have only done approx 5000km, i will be pulling out the spark plugs and cleaning the afm's tomorrow night, and also trying to follow the intercooler piping to see if theres a leak. I think ill need to pull off the front bar to see all the piping though.
I just cleaned all my spark plugs thoughly and checked over the coil packs and the harness, the problem is still there. I also had a quick look over the cooler piping and couldnt see any pipes off but i need to take of the plastic guarding to see all of it properly, thats for tomorrow night. Im so worried its something engine related (because of the oil smoke) and will be major work to fix, i just spend a shit load on replacing stuffed turbos with my car off the road for 6 months so i can not afford to do any engine work.
Well they are only as old as the coils (about 5000km if that) and are $20 a pop so id rather clean them rather than replace them.
Have you got an After market ECU.
Sound like the fuel is not burning properly...or you used poor fuel from a garage.
My sister in law filled up twice at the same servo and both times she could not get the car started the next morning.
It will blow heaps of smoke and splutter and kick like a mule till it has cleared the lines.I know cause I started it by pumping the gas to get the engine to kick.
I would suggest you report it to your last fuel station. Get a new fuel filter and maybe if your like me, dump your fuel.
I suggest all you out there to either use Shell or Mobil for your fuel.
All the rest may have quality problems and may or may not address then.
Good luck with the fix
Interesting. But i first notice the problem just before i got to a servo to fill up from empty and it has gotten worse with the new fuel. Both fill ups were from Mobil.
I am running the stock computer
Edited by Cooper
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
