Not a bad night last night, once i got my starts sorted though the clutch didnt agree and the pedal stuck itself to the floor... just what you expect from a brand new button clutch from direct clutch. Anyway, i managed a best of 13.4@105mph with a 2.2 60ft. The last run my 60ft time was 2.0 but i couldnt shift into 2nd because of the clutch, so with a theoretical best of 13.2 im pretty happy :D. With my over rich std ecu tuned im sure i could pull off a 12 :)
Also if anyone wants to buy it, let me know, selling it because i cant get comprehensive insurance, which is a must for your daily driver..
Cant get comprehensive insurance full stop, or cant get it at the right price?
Cant get it at the right price. I like the car, but its not worth $50/week on top of car payments just for the insurance. I called everywhere and the best i can get is $2100. Could get alot better but just car doesnt honor driving company cars to change your rating so with them i have a rating 5. Unfortunate, because i was looking foward to my motec/TD06 ugprade :P Famous were the cheapest at $2195 or so, with a few others around the same price. Just car quoted $2200 with rating 5 or $1200 with rating 1, which i would pay but cant get :D
I think im going to go back and try for a 12. The tyres on the car arnt that happy, down the the worn out marker. I reduced the rear tyres to 25psi, not sure if lower would help as they are 235/40/18's.
What are the opinions on the clutch? The last run i slipped it a bit to control the wheelspin, and it just held there and slipped even after i took my foot right off, and wouldnt release till i missed 2nd gear about 5 times :D Its a 5 puck brass button that direct clutch said it would be good for well over 500hp, i dont think that my car would be anywhere near that much, and are quite dissapointed
Originally posted by gtrhybrid
try to find a friend with tires on rims that are smaller that 18's.  Those cause more drag that you think and the low profile tires leave no give in the sidewalls, and that kills traction.
And the bigger diameter wheels have their weight distributed further from the centre so you loose torque.
(torque=force x distance )
Drag cars have small wheels for a reason.
A TD06 sure wakes up an RB20:D
I would never have believed the old girl could pull 8300rpm so quick and easy (I still havent discovered where the new rev limit is:( )
With just 8psi it spins all thru 2nd and blows the door off the std turbo with 15psi and a tank full of toluene.
Have you tried the usual i have an alarm, drivers education courses etc etc. Tried being a named driver on a parents policy
(not ideal, hey im paying $2600 a year because i have listed all my mods... well except for the new turbo but ill get to that in the next week or two)
Nice result, congrats:)
On insurance, if you can be careful enough, have you thought about just 3rd party fire and theft? It just means you need to be extra careful driving cos if its your fault your on your own - but, you will get to enjoy the car a while longer and every year that you have the insurance your rating will go up, so in a few years the comprehensive will be cheaper. Just a thought, cos this is how I got myself a rating one many years ago.
I cant find a company that will do fire and theft for more than $8000 value on the car, any ideas? I dont mind fulll coverage theft but not if it only covers 1/2 or even a 1/4 of the value of the car. Something i forgot to ask about when i was calling around.
I just applied for a loan for a BA turbo ute... 511hp at wheels with standard turbo and internals is just too inviting, even if it does weight 1700kg. if that falls back i might buy a mazda 323 and drive that as my daily driver or find somewhere that will insure fire and theft to the real value of my car, and save up for a TD06 and ecu :).
just a question back on the topic...
are you sure it's a clutch problem?
the clutch pedal sticking to the floor sounds like a clutch cylinder problem.
Like there it is sucking in air...
it's a lot cheaper than a new clutch dude.
get a mechanic to check it out..
A new clutch master cylinder and a slave cylinder seal kit for my R32 GTST cost less than $200 supplied and fitted...
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
