Firstly, i love my car (s1 stag), dont get me wrong, but there are a few issues. Mainly due to my excitedness/haste (read: foolishness) in buying i suspect.
1. I dont have an original stag key. I have a craaapy mr minit looking cut key, and crappy little press in immobiliser. I'm assuming car wasn't shipped with the key or something?
2. My power steering pump is making an inordinate amount of noise. (noticable mainly due to 3.)
3. Left side speakers blown.
4. Rust on INSIDE of door mirrors
5. Drivers side door mirror requires manual assistance in folding in/out
6. Twice now, car has stalled driving in shopping centre car parks (will check out fuel filter this weekend)
7. After 30mins - 1hrs driving it bogs down when accellerating from idle (auto trans fuild hot maybe?)
8. Current auto issues are making me save for a manual s2 already.
9. There are water marks on the top of the visors, and the rear portion of the roof has begun to hang down at the join. i'm suspecting that there may have been a leak through the roof although there is no visible rust or anything there.
10. It's already been back to have a belt changed because it almost deafened me with its squeal while my head was under the bonnet
so, i'll call it personality, it sounds more positive that way :blink:
i have my work cut out for me i think :)
https://www.sau.com.au/forums/topic/230800-stagea-issues/
Just remember you bought a 12 year old car and although most cars come from japan with low km's 12 years of sitting in the snow and rain will do damage,it could be worse you could of bought a 12 yr old commodore and be doing alot more repairing. Stick with it and be rewarded with a fun car im loving my stag and although it needs some attention i wouldnt trade it for the world atm.
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4054416
My car came with a key with built in locking/unlocking (maybe an optional extra?) if you can find someone to check via FAST (i Can't) you may be able to find out. I tried to buy another key but was quoted $300 from Nissan
Rusty doors under the mirrors is a Stagea thing (but the ONLY rust on my car). The sooner fixed the better. Door panels off, mirror off (maybe time to o/haul or replace the motor) weld in steel and replace or dry foam and put waxy stuff (panel beater told me) to prevent further rusting.
see above
Unlikely but see DIY section for installation of cooler - check fliud to see if its dirty and needs replacing
so, i'll call it personality, it sounds more positive that way ;)
i have my work cut out for me i think :teehee:
Not just a car but a past-time!
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4056881
hahaha I get really embarrassed by it.. damn car making me blush hahahaha
heh, mine squeals no longer, the offending belt got replaced and my ears have finally recovered ;)
apparently you can get a de-glazing compound to sort out the squeak on the belts if they're not too far gone, where you'd get it from i have no idea though :)
heading back to the dealership with a list of things to have sorted out tomorrow, i imagine not many will be fixed, but even if its only 1 or two then thats 1 or two i dont need to fix :(
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4059378
http://www.skylinesaustralia.com/forums/Ca...vs-t230750.html
I found this issue to be my AFM but it may be different to yours
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4059910
Yeah bro,
Happened to me on my first stag with the standard factory bov and everyone has a theory on how to fix this issue.
It is common on autos but can occur with manuals aswell. This caused lots of probs and I couldnt pin point it and also changed the afm.
I had the same prob when I went open atmospheric with an Apexi dual chamber and had to plumb back the right air flow on deceleration.
A aftermarket computer engine management system or SAFC II can fix this or you need a full plumb back system, I had the same prob on my GTiR with a SARD R2D2 and chose a HKS Eids.
Either of these will fix the idle/stalling prob, just depends on how much you want to spend and how far you want to go with later tuning and cost.
The SAFC II was the way to go when on the cheap, just up to +1 deceleration air.
Also leetom is right about the squealing alternator belt, just adjust, a new one will do it aswell.
Stageas are hard to find without rust and doors are usually common, its more along the lines of least amount of rust, mine is pretty clean though.
All stags need a full major service and overhaul when bought considering wear and tear on the usual items, it cant be avoided on a 10 year+ car.
As I said my second stagea..lessons learnt and still could maintain full open atmospheric venting..PSSSHHHTT!!
Edited by nismokid
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4060482
  • 8 years later...
Super Cheap sells a spray to fix squealing belts. Saw it in the shop today when I was looking for dielectric grease for my coils.
Shit this is an old post. Ha ha ha so tired.....
Edited by TMLP
  • Like 1
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-7787108
Blast from the past ;)
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-7787271
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
