  • Replies 281
it's ok i got a fantastic mechanic! anyway what brand are they?
OEM Mazda 550cc. Happily supporting 300+rwkw on my RB25DET at the moment, and up until ~17th Nov 08. Then out they come and in go the 780's.
^ bump ^
We've had a couple cars pull out due to engine trouble, not ready or being upgraded on the day of the dyno.
If your interested in running on the dyno we need you!
Domestics are only 2 cars short, however we are still accepting entries from higher power cars also.
Entries officially close on the 14th on November.
Cost is $30.
Date: 22nd November.
Time: 10AM till 5PM.
Apply here:
http://toyotacarclub.net/events/domvsimp/
Thanks guys!
I'm interested. However, my car will be undergoing a few minor upgrades at Boostworx around the 17th-20th of this month, and although it 'may' be ready in time, I won't really know until after the close date - the car could even still be there when the dyno day is on.
^ bump ^
Cost is $30.
Apply here:
Thanks guys!
can you post up bank details i cant seem to find the email
Me but i dont think i will get my new pfc in, in time i was ment to pick it up today but the guy couldnt meet me and now he is express posting from milicent or round that way, then i have to see if Shaun can wire it up as its a GTR pfc
Sorry Matt, I'm just reading this.... didn't it do that a couple years ago???
Hope to catch you soon!
Ha-ha fair call, Will :( What can I say, it started as a simple $3k turbo upgrade in 2006 and has since turned into a... ummm... maybe $10k long term project. The old set-up that ran the numbers listed in my sig' is not even close to the 'real world' grunt of the new set-up, and the new set-up isn't at full potential yet. At best I reckon the old set-up would've made 260-270rwkw on the BW dyno.
Unfortunately it won't be ready for the dyno day on Sat, so I'll merely be a spectator. Be good to catch up though mate.
it will work madaz, i got a gtr pfc in my r33 gtst
im thinkin of coming to watch/support the japs
im goin on a fishing/drinking trip friday night so not sure what sort on condition ill be in :)
chris, steve has GTS4t, maybe i little different.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
