  • Replies 98
Posted Images
^^^lol make up your mind R33 GOD hehe, so is it 12.20pm we are gona all meet up there, we will kick back have a laugh and as soon as gates open we will all go in
cheers tony
Your not very good at organizing things are you, gate sopen at 10 scrutineering starts at 11 so if you planning on getting in when the gates open you should be meeting at about 8am.
Edited by W0rp3D
ill double check, im about to give them call now
just got off the phone to them and yess thye do open at 10am, racing starts at 11am and she said some othet times for different races but yer guys im going to get there at about 12noon anyway
see yous there guys
cheers tony
Edited by GTRBOS
I was going to go up to Winton to do sprints but I may hit this up instead...
Now that everything is sweet with my car I want that low 11! HarHar
Just need someone to drive it to Calder for me ;)
Sounds sweet... will try make it :D
Unfortunately I won't run (as much as I want to) because my 4WD is not working. :laugh:
Same as me i might take in this week and see whats going on. If its fixed ill be running.
if the R34s registered by the 7th ill be there...but this events a week away now lol.. so ill see how i go. I might even drive it down on trade plates, considering i only live 5 mins away from Calder Park..
...know one laugh lol, coz it sounds like my skylines the only stock one within you lot! :blink:
Ok so im confused, now exactly wat time are we all meeting at Calder? And is anyone out from the west going there? If so, wana meet somewhere? Or we all meeting at BP?
been practising some launches. im nearly ready :thumbsup:
Dont bother, from what i have been told anything you do on the street is no where near the same as calder due to the surface being completely different and a lot more slippery.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
