Comes complete with piping/hoses/clamps/brackets.
Without looking at the HKS site or measuring i believe the cooler is 600 x 300 x 75mm. Thhe cooler is in good condition, with 1 dent in the bottom shroud that has bent a few fins but not damaged any of the tubes.
Currently installed on my R32, but i suspect the tubing was actually meant for an R33... either way it defintely fits a 32, and most likely an R33.
Reason for sale is that the std HKS piping no longer suits my setup. My front bar was cut to suit the piping, so new piping would look silly as it wont match the cutout in the bar...so R32 GTSt owners i would most likelybe able to supply you a silver front bar to suit, simplifies installation by hours.
Offers I will only sell it if $$$ gets me close to the cooler i want.
https://www.sau.com.au/forums/topic/23155-hks-type-s-intercooler-kit/
Guest darrinspencer
do you have any photos to view damage and condition of cooler and pipework.
how old is the kit. did you fit the kit or did it come from japan aready in the car.
i have seen these kits available new for about $1450 delivered including duty and gst.
considering that it is secondhand and damaged i will start the offers at $550 plus freight.
Can give you photos on the car, but doesnt show you much as i have used black mesh to hide/protect it.
The damage is about the size of the tip of your little finger, on the bottom shroud. If it was not for this one little imperfection that resides behind the bar anyway, i would have no probs claiming the cooler is 95% near new. Oh and i installed it 10months ago
$550 is a start
My thinking... (and of course im the seller so feel free to slap me around)
... was that 2nd hand GTR coolers go for $700-850, and this cooler is definitely in better condition than any 2nd hand GTR cooler i have seen (i looked at many before buying this kit)
Plus it comes with clamps/silicon hose/mounting brackets etc. So $700 is heading in the right direction.
I also have a HKS air filter that i COULD (but wont) claim is new for sale that will work well with this setup. Again with the correct bracket for an R32
I think this is the one:
http://www.hks.com.au/hks_cooling.htm
http://www.hks.com.au/Pics/HKS%20More/inte...%20type%20s.jpg
Perfect for horsepower applications 250-450PS (184-320KW)
Core size 600 x 301 x 65mm
hey this is the one i was checking out at eastern creek the other day?....im sure we can come to an agreement :)
so is the front bar free? its the wrong colour and its got all those holes in it! :)
pm a price your happy with
(p.s. the hybrid kit is going for $1100 which i will get soon,
probably)
nissky , like i have said to a few others, is it ok to let a bidding war start on this, as the money will go towards another cooler and piping, so can do with all the money i can get.
Photos up hopefiully Monday for those that havent seen it. n the meantime anyone willing to pay more then $700.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
