To put it in more detail...
1. Pop bottom part of back chair of, its just clipped in at two points... sometimes need encouragement with a leaver.
2. Undo to bolts at bottom of upright part of chair, use a socket, as the screwdrivers always seem to strip.
3. Lift top part of chair, Its secured by three hooks, lift and move seatbelts out of the way.
4. Pop out the parcel shelf.
Reverse order to put back, careful with putting back top part of seat on three hooks, as they then to bend if seat is put on wrong.
thanks guys! managed to get it out without removing the seat which was good. i don't really understand the purpose of those clips on the shelf though. they didn't seem to be clipping into anything! oh well, looks fine.
quick question though, what's the point of those brackets that sit over the speaker? obviously they're there for the big black things on top of the speaker grills to bolt into, but what're they for? i just left them off for the time being. cheers!
THIS is the method i would advise you to use.
Um I have had the parcel shelf out on various R32's & never once removed the rear seat. You just grap the cushion & pull it forward whilst you lift the various sections of parcel shelf. It is only timber anyway so will flex quite a bit.
this however is not.
they are child restrant brackets...for a baby sear or similar.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
