CRD Dyno day - DATE CHANGED - Now Oct 12th 2003
  • Replies 240
Grim: From what Jim mentioned to us he wont rush the cars on and off, so you should be able to have a quick play and adjust your settings - obviously cant confirm this until the day though.
Brett: I'll put your name down
Originally posted by benm
I think Brett should be made to run his car last on the day.
That's a good idea. We should be coming up with some sort of running order to keep the interest all the way to the end.
So Brett should run his stock GTS right up front :stupid:
T.
ok guys we are going to look at keeping it at 35 cars max so things dont get overcrowded. Limiting the cars will also mean that Jim will have time to answer a few questions for you before the next car rolls onto the dyno.
That said - first in first served. The list of people who have said they plan to attend appears in the first post.
hmmm.. i might wind the boost up and adjust my timing before hand then.
count me in.
Christian
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
