CRD Dyno day - DATE CHANGED - Now Oct 12th 2003
Originally posted by wrxkilla
so guys,
Am I welcome to come?
I need a dyno day. nice cheap dyno runs.
If So. And its that weekend 2 weeks from jamboree. lock me in eddy.
Is this the EVO 4 that was at the Performance Forums Dyno Day that got 250ish kw @ all four?
  • Replies 240
24 peeps and counting.
Anyone is welcome to spectate, and there is a chance some of those whose names are down may pull out so anyone who wants to come out and try their luck is more than welcome.
NOZILR: added.
Originally posted by franks
christian, are you turning up the boost just because you want to get a high reading on the day?
And you're not Frankie boy???
Let's just say that my turbo has steel wheels and ball bearings and you bet it's gonna earn it's keep that day!
T.
:D
T.
no way dude.
my car's been tuned for 1.0bar boost and thats what i drive with all day, every day.
why would i want to:
a) compromise my car for the sake of a big number infront of you monkey's :D
B) not give a fairer representation of what power im making when im on the street?
if i wanted big numbers just for that day, i'll bring a bottle of O2 and spray it onto the intercooler whilst its being dyno'd and blow you all away.
:lol:
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
    • I would tend to agree, especially based on the transfer oil being completely cooked by the sounds of it. I bet it was serviced every 5,000km... Which probably worked out to once every 15,000 real kms...
