Hey guys, just wondering how to keep the TV/GPS screen on S1 stag active while driving. When I first got the car with standard stereo etc it i could see snow when driving, now that I have got a headunit installed and running visual through AV2 it cuts out as soon as I put it in gear. Even when I try to view what I was seeing before the install.
Is there a way around this? I expect there is as I know some people out there are running GPS through this screen. Maybe when they were installing the headunit they did something, or is it just s setting or something?
I've tried doing a search but after several hours of reading I still havn't found what I'm after.
Thanks for your help guys :D
https://www.sau.com.au/forums/topic/232331-tv-screen-active-when-moving/
depends on the setup, but from my expirience, there is a wire connected to either the handbrake or gearbox, when the hand brake is on or the gearbox is in gear the circuit is completed and the tv shuts down, you will have to disconnect this wire.
all depense what you have. but if you pull out the screen it should have a 'to handbrake' or sumthing wire... unless its stock then mayb they might be a little more safe haha. but its just a matter of grounding that wire.
hey guys not to be a damper but be carefull what you post as it is Illegal and im sure a mod will delete your comments ban or warn ya's in some form. keep it private.
Edited by loymclure
You need a special harness that plugs into the back of your screen, looks like this:
http://www.amazon.co.jp/Datasystem-00TV-KI...3/dp/B000HP5J4A
It is not as simple as a handbrake switch, its a very complicated little harness.
Most/all japanese install them as soon as they leave the dealer, so look for a small button or black box, as in pic. Might have been 'touched' when your stereo was installed.
If you have no luck, i have a spare one available, pm me.
Yeah cheers chook, just the sort of info I was after. I have some wiring and stuff that was removed, will have a look to see if there is something there that resembles the unit you posted. I'll also ask the installer if he touched/saw something as well.
  • 11 months later...
Anybody know where you can get one of these boxes? Sorry Chook i cant PM ya as im new :)
cheers
No idea, I can't remember the branding on mine.
I can however remember atleast part of what was written on it "......so you don't miss your favorite show when you're behind the wheel" Aren't the Japanese so safety consous
other than in Japan, or possibly a Japan Yahoo site such as http://www.importmonster.com.au , 2nd hand ones are cheap there, or try Chris Rogers, part # datasystem NTV142,
http://search.auctions.yahoo.co.jp/jp/sear...=0jp&acc=jp
These are only for the factory xanavi screens, not for aftermarket.
I've ordered the "Data Systems / TV-KIT NTV142 / SUTEJIA W # C34/H9.8 ~ H13.10" through nengun on the japan yahoo auctions - next question... how hard is it to install with instructions in japanese??
for my dvd player handbreak wire is just earthed.
for an aftermarket headunit, that's all it'll be. run it to a switch so that you can prove to cops that it's legal though :P for the standard xanavi unit though, you'll need the harness like Chook said.
Edited by pyro-ns
plug and go. I sell a few of them myself.
getting arounf that unit is best done with a bypass. there's too many wires to fiddle with otherwise.
Plug and go? Hope its as easy as it sounds...Lets hope its nothing like the windows plug and prey...
Cheers!
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
