  • Replies 373
Posted Images
http://ripsltd.com/products.html
that basicaly goes through everything. if you are only looking for 300-350kw range the stock internal bottom end is fine (good for 600hp and 7200rpm) remember that all pricing on their site is in NZD not AUD.
Anyone know where is good to order online that is pretty quick?? I am after parts first week of November. Got a few places but not sure if they have all that I need so would be good to shop around.
Cheers :banana:
Send it up Kat...our head work is top shelf PM Jz R33 as we just did an engine for him that he picked up on Saturday.
Our engines have a proven track record taking out several Autosalon power championships and powering our R32 drag car to win the Australian title in 2004-2005. We have just built our current engine in our race car to push over the 1000hp mark and into the 8 sec bracket.
Im doing a couple of engines for ACT customers actually...you may know some of them.
Kat, make sure you consider this post!
LOL I'm happy to have 4wd and the more power she gets the happier I am! Haha rather have traction than fishtail down Gungahlin drive like what was happening when I had no front wheels engaging! :)
Do you know what yours dynos at the rear??
no idea at the moment...only got a 3 inch zorst and pod so i cant imagine more than 140ish 150ish at the wheels...plus i took the boost controller off so its running stock boost at the moment :) still enough compared to the old pulsar but.
it's booked in to autotech next tuesday, they are going to check air / fuel, try and diagnose that sensor problem thats making the car feel crap. hopefully give me a power figure then. when i spoke to the guy today he said it might jsut be easier to get a power fc so i can tune it n stuff...we'll see.
i bet the fishtail was fun hey? i had my first powerslide incident coming out of a round about the other day when it was raining...not as bad as what i expected it to be but...
Power FC FTW!!! Best thing I ever bought for it.... So far :)
Compared to the Pulsar must feel like a rocket!! I remember getting in the GTR for the first time after driving around a non turbo for 4 or 5 years... Haha OMG!!! :)
Well I've always had good results from those guys so they should be able to sort it out for you. I wasn't sure how stock yours was. At least it's nice and tidy, I like stock so then you can do whatever you want to it. Modding = expensive but awesomes!!!
LOL was a bit embarrassing cause was unplanned!
yeah my awesome powerslide was pretty much me jsut out of a roundabout...was going straight and put my foot down...hit boost was fine...hit 4K = loss of traction pluss bit of a kick
was kinda cool hehe.
where di u source your FC from kat??? can autotech get them or do i have to go through an online shop?? ive never shopped online before lol :) somewhere local supply them??
guess ill wait for them to tell me what the problem is first.
Sinista v1.0 (Black GTST) ran 178rwkw. Pod, Zorst, T-peice boost controller and 2530 turb.
Sudden stop at metal bus stop by next owner ~ 0rwkws :)
Wit you Jayce 3 local votes
Edited by Sinista32
Guys that have done this all before me, can you please let me know wht brands you have used for....
Cams
Pistons
Conrods
Injectors
Oil Pump
I have some ideas now and wanna hear what everyone else is using :banana:
Cheers.
Just been through it all, engine is at the builders now!
Cams: Tomei, Hks or other (not sure were already in engine)
Pistons: i went with Mahle pistons (Probably one of the best pistons you can buy) were around $900
Conrods: i went with Pauter. (also one of the best money could buy at the time) also were around $800
Injectors: i bought some 800cc injectors (i think they are denso) from slide on this forum (in the for sale trader section)
Oil Pump: Using N1 pump still. (with a well balanced bottom end, and staying away from rev limit launches etc they will be fine) will be looking at dry sump later on
Best thing to get is the nismo full engine gasket kit too @ around 4-500 bucks its very good value :P and you wont have problems with leaky aftermarket gaskets and seals..
I bought most of my engine parts in the Usa, while the dollar was at around .95, therefor i spend a bit more money and got myself Very good parts.
also got a n1 water pump for around 200 bucks from the usa..
As for other bits and pieces (jap branded stuff) got most of them from www.greenline.jp
I'm close to the 10k mark already tho i did buy a complete n1 motor as that was ment to go straight in........ haha
Edited by Angus Smart
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
