as topic says
i was told by a mate after i bought it that it doesn't fit just by sitting it in the boot, you need to put it on an odd angle in the spare tyre tub...
wondering if anyone has got a trick way of fitting it nicely?
thanks
perhaps be more descriptive in your question next time and you might get a more descriptive answer.
is the box you want to fit a genuine alpine box or is the sub just in a wedge style pre fab box? if you can take a picture of it.
the pre fab wedge style boxes fit snugly under the parcel shelf in a 32.
and seems you have already bought the sub and box why dont you just put it in and see for yourself lol?
theres a reasonable height difference in the space under the parcel shelf in a 32 compaired to the hight available in a 33.how much clearance did you have between the top of the box and the underside of the boot lid?
hey mate i know wat you mean. I have a r32 with a genuine alpine 12" sub box and i lied it flat and it still doesnt fit. Had it sitting in the wheel well for a bit but gets chucked all over the place. Ended up making a wooden floor in the boot and bolted it down. Its the only way to do it if you wanna keep that box. Limits boot space but if you wanted boot space then why did you buy a skyline? :laugh:
someone told me skylines where great family cars and with the high petrol prices you would save heaps with the fuel economy that you would get from owning and driving a skyline. boy did i get fooled.
Ah... I get worse fuel consumption than anyone i know. Including 5.7L V8's and SR's etc... oh apart from GTR's lol they are REALLY bad
Cant you tell its not a family car by the size and fact that 'most' skylines have 2 doors?
Anyway let me know how you decide to mount the sub as i am interested in any other ideas ppl may have...
Edited by BennettR32GTS-T
yeah boot space doesn't bother me, i just don't want it on some retarded angle and getting thrown everywhere as you said
today is the day i'm going to try and fit it so we'll see what happens, might go and change it for another brand one at JB if it doesn't fit
thanks matey
Make one yourself. A bit of MDF, some screws and some carpet.. Not hard.
I fitted a nice sized box under the parcel shelf with an angled back to use all the available volume against the back of the seat. Still gives me useable boot space. R32's don't really need a rear strut brace luckily.
So your just going to slap some wood together and hope for the best?
Its not that simple im afraid,subwoofer boxes NEED to be calculated and designed for the particular model sub you intend on using wit it.
Its like sticking a truck turbo on a little RB20,it will not perform well at all and in the end blow something up.
Im more then happy to design a box for you so you only have to follow my design and build it to spec.
Jack
I didn't say that, did bennett or mysterykid? Mine has the right volume for the sub that I had, for the response I wanted (god knows what it is cos that was a long time ago and I don't care that much about it).. just so happened to fit nicely under the parcel shelf with a bit of jiggery-pokery.
Edited by heller44
Jack88 - I already have the genuine box and i was going to measure the volume of it then make it about 10mm lower and adjust the width and depth accordingly to get the same volume. Do you really think this would affect the sound quality?
in answer to both of you, sealed boxes and generally fairly forgiving so a decrese in box volume by such a small amount wont really affect anything,you probly wont be able to hear the difference at all anyway. so you dont really have to adjust any dimentions.
yes thos type s's go pritty well in a sealed box too,for the money there an excelent sub.
Jack
EDIT are you planing to just built a whole new box or modify the alpine one? is the alpine one a sealed box or ported?
if its sealed box decresing the volume will just raise the tuning frequency a small amount which you probly wont be able to hear the difference.
id recomend building it equal in volume as the original one just to keep things the same,if your already modifying part of it you may as well do it all properly.
Edited by Jack88
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
