Jack88 - The box is sealed. I was going to make a new box from scratch. Another sealed one just a tiny bit shorter so it fits. Will have the same volume as before.
Zennon - Is your box the rectangle one with all sides straight? Mine is on an angle so one side sits higher and thats the bit that hits.
Turbo Piston : the pioneer slim line subs are a waste of time unless you absolutly canot fit anything else in there of decent size lol. my DD 6x9s ate there 12 slim line sub alive for quality and depth. as i said tho if you cant fit anything else at all then they do an ok job.
BennettR32GTS-T: ok no worries that will be fine.
one side (side with sub) is slanted - all other sides are strait
general shape kinda like this:
Yeah mine looks exactly like that and if i can find a nice square one theat fits ill buy it cos yeah i really cant be f**ked. Ill go get one off my mate who runs a stereo shop That would be the smart idea hey? Anyway thanks for all ya help guys.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
