I'll be in this for sure. its always good to know how your AFR's are doing....
1. CeJay
2. Ex!$t3nZ
3. R33_ACT
4. Turismo Skyline
5. GTRKat
6. mccready
7. ZCR
8. DriftGTS
9. Pintaline
10. EVL-R33
11. Tarmac-
12. Frink
13.
14.
15.
16.
  • Replies 115
my mate with the R34 is in
1. CeJay
2. Ex!$t3nZ
3. R33_ACT
4. Turismo Skyline
5. GTRKat
6. mccready
7. ZCR
8. DriftGTS
9. Pintaline
10. EVL-R33
11. Tarmac-
12. Frink
13. Andy (pintaline)
14.
15.
16.
Keen as balls
1. CeJay
2. Ex!$t3nZ
3. R33_ACT
4. Turismo Skyline
5. GTRKat
6. mccready
7. ZCR
8. DriftGTS
9. Pintaline
10. EVL-R33
11. Tarmac-
12. Frink
14. NaughtyRuski
15.
16.
Ah why not
1. CeJay
2. Ex!$t3nZ
3. R33_ACT
4. Turismo Skyline
5. GTRKat
6. mccready
7. ZCR
8. DriftGTS
9. Pintaline
10. EVL-R33
11. Tarmac-
12. Frink
14. NaughtyRuski
15. sl33py
16.
Happy to start at 9am can start later, but looks like theres a good half days number of cars for the dyno day so far.
1. CeJay
2. Ex!$t3nZ
3. R33_ACT
4. Turismo Skyline
5. GTRKat
6. mccready
7. ZCR
8. DriftGTS
9. Pintaline
10. EVL-R33
11. Tarmac-
12. Frink
14. NaughtyRuski
15. sl33py
16.
17.
18.
19.
20.
Just because it starts at 9am doesn't mean you have to be there at 9am :) , just means you might need to wait a while when you turn up, as long as theres 4 cars or so there at the start, that should keep the dyno going for 40-60 mins.
1. CeJay
2. Ex!$t3nZ
3. R33_ACT
4. Turismo Skyline
5. GTRKat
6. mccready
7. ZCR
8. DriftGTS
9. Pintaline
10. EVL-R33
11. Tarmac-
12. Frink
14. NaughtyRuski
15. sl33py
16. sfrizza (Sam - pending engine state from previous week)
17.
18.
19.
20.
I forgot to add my name to the list in my previous post... doh!
1. CeJay
2. Ex!$t3nZ
3. R33_ACT
4. Turismo Skyline
5. GTRKat
6. mccready
7. ZCR
8. DriftGTS
9. Pintaline
10. EVL-R33
11. Tarmac-
12. Frink
14. NaughtyRuski
15. sl33py
17. Spanna (ns.com)
18. Annadrolic (ns.com)
19. T34M_DD (ns.com maybe)
20
Pretty full at the moment. Should be a good day.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
