I found this on another forum, not sure if its on here but i thought i would post it anyways.
Here's a guide on how to carbon overlay parts of your car.
You will need the following parts -
Carbon cloth (twil looks best)
resin
acetone (if u want to clean your brushes - i use cheap ones and bin them)
plenty of latex gloves
mixing pots
measuring jug
syringe (for measuring hardner)
masking tape
Sharp scissors
Some stirrers - I use wooded spatulars
emery cloth
wet n dry 400grit to 1200 grit
polish
1) measure up your carbon cloth for the piece to be covered. Then using the masking tape tape up both sides where you intend to cut the cloth to prevent pulling the weave then cut through the middle of the tape -
2) Prep your piece to be overlayed - it should be black, if its not spray it up first so a colour doesnt show through the weave. It also needs a rub down with emery cloth.
3) brush a thin layer of resin mixed with 1% harder over the part to be overlayed then press the carbon cloth gently into place and tape up to the rear of the part to pull it into shape. You may need to change your gloves often so you dont pull the weave. Leave to dry for approx 45mins
4) Start building up thing layers of resin, you will need approx 5 layers to prevent breaking through to the cloth when sanding down. Each additional layer should be added after around 7 mins when the previous layer turns to a jelly consistency. You will now need to leave it for 1 week to fully cure -
5) you will now need to trim the excess cloth off - best tool I found was a dremmel -
BEFORE:
AFTER TRIMMING:
6) Start sanding down. work your way from 400 grit up to 1200 grit wet and dry then finish with a good quality polish for a really nice shine -
https://www.sau.com.au/forums/topic/233499-how-to-carbon-overlay/
Well not sure where in AUS u can buy the rolls but u can get about 90 sq. ft. for about $250, from the US, which would be more then ample to do a full interior (gear surround, dash ...ect...) i would think.
http://motors.shop.ebay.com/items/_W0QQ_fr...mp;_trksid=m270
Thats from the US but i im sure u can get it from other places within AUS at about the same price.
tip: when your letting it cure in your garage or whatever, put some lighting onto it, like a bedside table lamp or something that gives off a bit of heat (like you do when making homebrew or something). if its small you can leave it your oven (!) overnight if you can be bothered to sit and watch to make sure you dont burn your house down.
i definatly know that you CAN get rolls in aus, but i dont know where from.
just on the carbon rolls, My brother is a boat building / repairer by trade, and almost all the work the do is fibreglass,
anyway he said can order massive massive rolls of this overlay shit, he is considering usuing some to do up a few body piece on his car, (( he is making his own fibreglass guards bonnetc, boots etc
anyway, offtopic, for info on rolls, perhaps enquire a boat place local to you?
thats soo kool too bad its soo expensive to do and if u stuff up i guess ur fkd?
Carbon fibre prices are currently very high because there is so much demand from Airbus.
For some types of carbon fibre there is currently a long waiting list just to get raw materials.
- Adam
Edited by TheTunersGroup
in addition might be of help to sand down the original part evenly, just enough to make up for the thickness you're gonna be adding with the layer of cloth and all that resin. Especially areas that butt up against other parts and might be a tight squeeze. remember with CF you can always add more resin to make it look bigger, but you can't remove when its set.
This might be a silly question but i take it this is just an overlay yeah so your stock parts are just covered in real looking carbon fibre. This is not how you mould a whole dash is it. If not how would you make a mould for the dash. Got a mate interested in giving this a crack as well he has been thinkin bout giving it a shot for ages. Only reason i ask is the pic you posted it kinda looks like you have peeled the carbon off the stock part as in a mould. If that makes sence
Yes
No
To do what you're thinking is a lot more involved than just laying a sheet of carbon cloth on it and resining it up. You need to start by protecting the dash (foil, gladwrap, tape depending on the chemicals you're gonna use). then spray it with a coat of gelcoat, then lay fibreglass on top of that. once the fibreglass has started to tack, you might wanna build up some wood reinforcement so that it holds its shape when you pull it off the dash. Once you've got all that done you'll have a mould, which you can use to make your plug (replacement dash).
indeed, be very careful about putting resin hardened carbon cloth in front of your face in a car when it can flex. unless you like picking shards out of your eye. as stupid as it sounds, that's one instance where a fibreglass backed CF would be better as it won't splinter as much.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
