Tuesdays?
There were a couple of informal meets but nothing 'regular' as such.
Last 'regular' meets were back in 2002/2003 in Wed/Thurs nights every week :)
Now its more every 2/3/4 weeks or whenever someone posts up in the events section about it, so check there!
https://www.sau.com.au/forums/topic/234245-meets/#findComment-4104769
1) cops came to the last one and defected people.
2) some members couldnt make it anymore due to loss of licence :)
Haha my ears were burning Matt lol. Dw ill try get these wastelands meets happening when i get my licence back. Havent had Rock Kung (DUCKKKK###$#$%%#@) for ages and we must get AP to annoy that waiter lol
https://www.sau.com.au/forums/topic/234245-meets/#findComment-4105149
hahahah yeah...def must have a meet like that again!
https://www.sau.com.au/forums/topic/234245-meets/#findComment-4105155
I have a memory of SAU meets being on a tuesday night.
is that still the case?
If not does anyone wanna meet?
Hey Matt!
Yeah West side meets were on Tuesday nights a few months back, I went to a few of them and always been pretty good.
BTW after you dropped off Murphy, Dax and all at The Link when we all meet up, did you just leave and went home?
https://www.sau.com.au/forums/topic/234245-meets/#findComment-4111206
^^ Ah a night 'In' with the missus... LOL! Yeah I catch your drift...
Yeah we just had a few more drinks then went to the Carlton Club on Burke St.
I left at around 2am and the rest went to BANG. I think it was a good night too, but I really needed some sleep.
Yeah meet up will be good. Just PM me and a few memebers or speak to dezz and he can get a big meet up organised.
https://www.sau.com.au/forums/topic/234245-meets/#findComment-4111276
did i hear DUCK?
yea we shall hold another DUCK RUN, an annoy my waiter friend
an for all yall that CANT drive i am sure we could pick your ass up
https://www.sau.com.au/forums/topic/234245-meets/#findComment-4111708
did i hear DUCK?
oh sick that works out perfect for me considering i live what 1.5hours away from you ;)
let me know what time you will be dropping by :)
https://www.sau.com.au/forums/topic/234245-meets/#findComment-4111964
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
