http://www1.biz.biglobe.ne.jp/~GT-R/autech32.html
have a look at this if your interested in the Autech RB26DE
it has some damn nice extractors, 6 individual throttles(!)
has an r32 body shell, though its a bit heavy for my like'n, 1480 kg
that figure sounds more like an r32 GTr
Im a huge na skyline fan, i would freakin love this car !!
  • Replies 321
Oh and by the way, the basic specs are (to the best of my ability)
4580~1695~1360 mm
ƒƒzƒC[ƒ‹ƒx[ƒX„@@@@@2615 mm
ƒweight„@@@@@@@@1480kg
ƒengine„@@@@@@RB26DE
ƒpower stroke„@@@@@@@@220PS /6800rpm
ƒtork„@@@@@@@25.0kgm/5200rpm
ƒwheels„@@@@@@@@@205/55R16 88V
For us engols speakers:
It goes with 32 R and as for NISSAN which is overtaken, 4 door editions GT whose request from the part owner extra troop is many - it announces 4 doors Gts-4 of 32 where even R you can say based AUTECH VERSION. With the photograph it is understood a little and perhaps, the ‚¸ leprosy, but the ornament has become SKYLINE26. On the rear the spoiler for 4 doors is attached with option.
Å‚o—Í:220PS/6800rpm
Å‘åƒgƒ‹ƒN:25.0kgm/5200rpm.
The rich torque which extremely occurs low from revolution, made nimble takeoff acceleration possible. The power which reacts to linear in throttle work. Passing power peak, the smooth blowing rising which continues. It is low, you can taste the good quality of the natural air intake engine which reacts sensitively to the movement of the accelerator from the rotary limits to the high rotary limits. Basic mechanism the ‚× - to designate RB26DETT which has the result as a racing engine as ƒX, the intake, as for exhaust, the camshaft and the piston etc. the Otech special made. Special tuning for this engine is included in the control computer. As for exhaust manifold stainless steel make isometric flexible pipe. Exhaust interference is avoided, charm twin cam sound is given Qin coming out. Actualization of the high braking efficiency where it corresponds to the power efficiency which is superior. In order reduction of unsprung weight and to increase heat dissipation characteristic, the caliper of the ƒAƒmƒŒƒ~ alloy make - with it has done. Front opposition 4 piston, rear opposition 2 piston. As for the brake rotor, the turbo fin model large-sized ventilated disk which has the sliding surface pin hole. As for rotor diameter, front: 296mm and rear: 292mm. Controlling this powerful braking effort effectively is ABS (the anti lock brake system). With control of synthesis with the drive system, ABS original antiskid efficiency and the braking efficiency which in the road surface which the snow ˜G and the like it is easy to slide are superior are shown. As for suspension layout 4 wheel multiple link suspension. It has made the specification whose rigidity is high making provision for the increase of 4WD conversion and suspension input. In addition Bridgestone EXPEDIA S-01 (205/55 R16 88v) you prepared in the private tire. As for tuning of suspension system, low as for the medium speed limits the cornering efficiency where in the high-speed limits are high from the first it has been compatible the riding comfort which is superior beautifully. The sense of security and the mild riding comfort which feeling inhales to the last exactly in the road surface and is attached. If crew-member everyone tastes, there is a real value of this underside in very the sense of relief which is not.
(From catalog part excerpt)
Guest neoGT-25
THAT LOOKS MAD!
and thanks for the advice guys... so to get it right, the 2.25" would be more responsive than the 2.5"? could you guys please explain? :)
and also should i get stainless?
thanks all... byes ;)
PS: Im getting a datto 1600 as a runaround car :burnout: (haha ill put a SR20DET in it ;)) not really :)
well the exaust should be stainless because alot of water vapour goes through the exaust, and if it isnt rust proof then eventually you will have leaks in the pipe work, this will make the car loud as hell.
While gettin the 2.25 will increase response over the 2.5 because it has less back pressure, or in other words it should have a bit more torque down low in the rev range. This addition of torque will make the car more fun and responsive to drive. It will also has less drone in the cabin.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
