Hi all,
Just wondering what the differnce is between a JJR fmic and say a greddy with prices around $350 and $700 respectively?? Are the performances similar? and why should i buy a greddy over the jjr??
Cheers
Edited by R3sp3ct
https://www.sau.com.au/forums/topic/234582-fmics/
ease of fitment. quality of workmanship.
That's true... and as with and car mod/upgrade/whatever, you get what you pay for. The jjr one might be good for a VERY mild street car but when you start doing upgrades to your car and start putting more boost through it, you'll start noticing problems with leakages through crappy welds, etc. Do things right the first time with mods and you'll save yourself a fortune :)
https://www.sau.com.au/forums/topic/234582-fmics/#findComment-4109690
That's true... and as with and car mod/upgrade/whatever, you get what you pay for. The jjr one might be good for a VERY mild street car but when you start doing upgrades to your car and start putting more boost through it, you'll start noticing problems with leakages through crappy welds, etc. Do things right the first time with mods and you'll save yourself a fortune :down:
And if you live in New Zealand then the JJR one almost equates to the cost of a Blitz LM with the rediculous shipping costs you Aussies throw at us :P Plus exchange rate pwnage.
And again of course ++ Respect
Edited by gotRICE?
https://www.sau.com.au/forums/topic/234582-fmics/#findComment-4109812
Gotta take into account the application.
For a 250rwkw car or something similar, a JJR is the way to go cost vs gain.
Although if your chasing serious power on a serious setup, the you might be better off using something better suits (ie, more costly)
https://www.sau.com.au/forums/topic/234582-fmics/#findComment-4109903
The new spec LS Greddy cores are 30% lighter over the old ones, are tube and fin over bar and plate, are fairly cheap at around $650 off the shelf for the kit and fit perfectly, not to mention look great. Probably one of the best buy intercoolers on the market IMO.
Edited by PM-R33
https://www.sau.com.au/forums/topic/234582-fmics/#findComment-4111301
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
