To all SAU's,
There is anotherthread on the forum that describes how to re-wire your fuel pump so it recieves the full 13.8v that comes direct from your battery.
PARTS USED-
-1 metre of 6mm Red Power Cable
-2 metres of 6mm Black Negative Cable
-5 x 30 AMP Fuses
-1 x Fuseholder to suit Fuses
-1 x 12v DC Relay or Horn Relay (You'd want a relay with big terminals to fit your 8GA Cables)
-2 x Large Eye Connectors to suit your 6mm Cables (Big enough to fit on your Battery and Chassis Bolt)
-Pack of 25 Fork Connectors to connect to your Relay Terminals
-Pack of 10 Straight through connectors to suit 8GA cables
TOOLS-
-Pliers
-Crimping Tool
-Phillips and Flat Head Screwdrivers
-10mm Socket and Ratchet
-Multimeter (To check your voltage after modification)
LEVEL-
Low to Medium
I've tried to explain it a lot more in depth to make it easier
DURATION-
1hour - 1hour 30mins (depending on electronics background)
CAR IN USE-
1994 R33 gts-t
DIRECTIONS-
1. Disconnect the negative from your battery, loosen with 10mm socket and remove. This is to make things safer and so you don't damage your ECU.
2. Locate your fuel cell, mine was in the boot on the right hand side of my battery.
You will see cables taped up leading towards into the fuel cell lid. Start unwrapping the tape approximately 100mm from the the fuel cell lid until approximately 150mm of cable is visible. This allows enough cable to be cut and joined.
3. You will find 5 wires in total. You may notice that 2 of these cables are a little larger in diameter than the rest. These are your POWER wires feeding your pump. The other 3 smaller diameter wires are for your fuel level sensor.
YOUR ACTIVE CABLE IS THE BLUE ONE.
YOUR NEGATIVE CABLE IS THE WHITE ONE.
4. Cut both of these wires in the middle of the section you unwrapped.
5. With the white cable that you cut, strip the cables back 10mm and twist them together and crimp one side of your straight through connectors onto these twisted cables. Join your 6mm Black Cable to the other side of the straight through connector and run it neatly to your point of earth on your chassis using an eye connector (loosen nut/bolt with 10mm socket, place eye connector on and tighten back up). Now your fuel pump is totally grounded.
6. You now have your two blue POSITIVE wires that you cut leftover. Connect the side of the blue wire that comes from your computer to the coil of your relay (Terminal A1) using your fork connectors. This will be your switch wire, so when your computer tells the fuel pump to turn on it will switch the relay on. Then connect the other side of the blue wire that leads to the fuel pump to your N/O (Normally Open) side of the relay with another fork connector.
Normally Open means that the switch will be open in it's normal state (when there is no power going to the coil), when power is put on the coil (when the fuel pump switch turns on) it will close the switch and thus turn on your fuel pump.
8. Now Connect your 6mm Red Cable to the positive of your Battery with your Large Eye Connector and neatly run it to your relay. Connect this to the other side of your normally open switch with a fork connector. This will now feed your fuel pump with full 13.8v.
9. Your last connection will involve you to connect your 6mm Black Cable to the other side of the coil (A2) on your relay using a fork connector, and neatly run this wire and join it to your point of earth on your on your chassis (loosen with 10mm socket place eye connector on and tighten back up).
10. Here is a detailed wiring diagram. Obviously you can't see white wires on a white background so instead i've made this YELLOW.
11. Double check all your wiring. Reconnect your negative terminal on your battery and start your car.
Check the voltage going to the pump, you should now have 13.8v.
Hope this has helped out a lot of people.
Any questions, feel free to ask.
RJ
https://www.sau.com.au/forums/topic/234796-re-wiring-your-fuel-pump/
I have just done this to my r32 with a rb25det. I just ran a new wire from the battery straight to a circuit breaker then more wire to the old power wire on the fuel pump plug. Added a relay in there so it comes on with the ignition. Does this sound right. Seems to get 12.8 volts at all times now but not sure if it is a safe way to do it.
Yeh its fine mate, aslong as you're still using your existing fuel switch wire to switch your coil on the relay you should be sweet.
The power from the battery should ONLY be powering your fuel pump.
This is so if you are in a crash or anything the fuel safety cut out will still switch off your fuel pump through your existing switch.
Hope that made sense.
  • 1 year later...
Will this have any effect on the battery. Mine was just rewired and I notice the batt voltage dropped to 9V after like 2 days of not driving her. It has gone to the point of having difficulty to crank her up.
it won't affect the car when the ignition is off
the wire that has come from the ecu to fuel pump is now the trigger wire for the relay when you do this, which means if you did have an accident and the ecu wants to turn off the fuel pump it still can cause i will just trigger off the relay which will stop the connectivity from the battery to the fuel pump. so pump will be off.
i did this recently, i had a bosch 040 in tank still running off the standard loom and i checked the voltage going to the pump and it was only 10.5v after runnin power from the battery to the pump just the noise increase told me it was working 1 hell of a lot better fuel presure shot up by about 10 psi at the regulator
i recomend this to anyone with a aftermarket fuel pump
sorry R 2 THE J but i think your wiring diagram is confusing....
  • 10 months later...
R34 gtt fuel pump wiring
Green white needs to go from fuel pump to chassis earth.
Green white from ecu to pin 86
Black yellow from ecu loom to pin 85
Black yellow from fuel pump wiring to pin 87
battery 12volt supply to pin 30 with a 30amp fuse at the battery end of this wire
If I want to do this, does this mean I need to open my fuel tank again coz I'm wondering if its safe to increase the wires outside the tank and not the inside(increased amperage and voltage flow will heat up the smaller wire inside).
Are you guys changing the wires inside the fuel tank(from inside the cap to the fuel pump it self)? If so what wires are you using because I really wouldn't trust regular wires near petrol as the plastic/shielding shit is bound to wear off and crack like arse and I really don't want sparks inside the fuel tank. In my old skyline I noticed they added two wires in place for each terminal going to the lid of the pump but inside was the same(I think).
What I done was remove the whole fuel tank lid and pump setup out of my old car and dropped into the new one and just plugged in the standard loom.
Edited by SargeRX8
we just connected into the wires outside the tank lid - easy way, dont think its an issue, besides when u open the lid, u need to change the goddam black rubber seal as it expands and is hard to put back in and starts leaking - I have a fuel smell in my boot now..where do i get the new seal from?
i got it from Nissan for 14 but there is a 3 week wait on it. You can get em fro kudos for 30. Nissan get them from japan they don't hold stock locally.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
