Guys FYI.
I recently had the Bilstein spring and shock kit fitted to my ARX.
The improvement in handling is everything I expected. It still has a 4WD feel, but is crisp and the floating feeling is gone.
On the negative side, the car is now too low for my taste, scraping on every speed bump in shopping centres.
To put this in perspective, it is worse than my 300ZXTT.
Ben from north shore prestige is looking at harder, original height, springs as an alternative to the Bilstein lowered springs.
Given the long wheelbase of these cars, I suggest you carefully consider your intended usage before lowering them.
I will keep you informed of our progress.
https://www.sau.com.au/forums/topic/234950-arx-suspension-experience/
Guys FYI.
Have a read of the SK suspension thread. You should be able to adjust the ride height by moving the position of the circlip on the Bilsteins (that is the shocks) unless you have very much shorter springs (presumably not Bilsteins). I lowered my Series I Stagea by about 30mm so I have plenty of ground clearance except when angle parking on old fashoined high kerbs.
Guys FYI.
Mate I had the same problem. There is a cir-clip on the front shock.....the bottom setting is to low....I have set mine to the middle....the top setting is not to high either. Are your springs grey in color? If so there are eibach springs not the original Bilstein spring(PS Eibach are a better spring).....there is also an Eibach agent in Austalia and they can make your springs to any spec.
If you want the original ride height the cheapest way is to go back to the original springs or get them made.
Edited by Jetwreck
Just curious, anyone know what the standard M35 (non-arx) ground clearance is?
My previous stagea (s2) had 15cm clearance when stock...wondering if the M35 is different - meaning that yours may sit lower than a C34 with the same setup?
The standard suspension on an ARX makes it float like a boat. Way too soft.
The Bilstein suspension upgrade option includes lower springs and the car I test drove was fine on speed bumps around Chatswood. I thought that just upgrading the shocks would leave the car still handling poorly and that since the kit has been specially designed for ARXs, it would be fine.
I was partially right. - The package is great, the handling is much improved.
I did not try it on speed bumps in shopping centres. So now I need to get it a little higher. - The circlip machining idea sounds promising.
The purpose of the post is to warn others who may be thinking of taking the Bilstein option of what I see as a problem.
mm
I did not see your answer to the colour of your springs that came with your Bilstein Kit? I know Jetwreck got the grey springs with his kit and his car sits lower than mine. (tested on his driveway, his scapes, mine doesn't)
I got the blue springs with my kit in the Bilstein box that I believe are the original shock for this kit.
I agree the kit drops the the car about 40mm from standard ride height of 180mm to 140mm. I have not had any real problem with speed humps and scraping other than when I have had my car loaded with 5 fat arses and then it is an occasional scrape.
I also just loaded my car to the hilt and did a tour of Victoria including a trip to the top of Hotham and many country roads and had no issues with the ride height scraping.
If you are buying the suspension upgrade check what springs are being supplied. This seems to be the difference in the ride height.
Cheers
Andy
Edited by andy65b
This may be a silly question, but why would you buy a car that's built to be raised higher off the road than standard, then change the suspension so it's lower?
Why now just buy a different version that was made to ride lower to the ground?
Which is the other model that comes standard with a wider track, V-Hicas, Attessa and 18" rims? An is easy to find? On top of that all the luxury items? I know the AXIS does but it's $5,000 more expensive and still does not always get the Attessa or V-Hicas.
Also my shocks were gone when I got mine...have you seen the price of the standard Nissan shocks for the ARX?
The grey springs are Eibach not Bilstein.
That’s my dilemma, do I buy an AR-X and go to the hassle of lowering it, colour code the moldings and maybe upgrade the front to look like the AXIS. Or just be done with it and buy the AXIS?
Still haven’t decided…..
So you want a car that looks like an Axis & handles like an Axis?
Why don't you just get an Axis then?
You can get all the luxury trimmings of an AR-X in an Axis.
Thanks for the answers to my earlier question & sorry if I'm hijacking this thread.
To those of you who have bought ARXs, can you tell me more about the suspension?
Is it a case of "this suspension isn't sporty enough for my liking", or is it more like "this suspension feels like it belongs on a crappy American family sedan"?
And also can you tell me if the car meets your expectations?
I've got my eye on one, but I'm facing the same dilemma - ARX or spend the extra on the (better looking, in my opinion) Axis?
Cheers - Sven
I went through the exact same thing.....AXIS....ARX....AXIS.....ARX.....I was bidding on both but what I got was a great deal so I ended up with the AR-X....and a lot of change in my pocket to get the car to how I wanted it.
In the answer to sporty or a bus on cross-pliers(american shitbox).....The AXIS is the more sportier model being 100kg's lighter and is already set up pretty good.....but that is nothing a good set of springs, shocks and swaybays cannot fix on the ARX. Remember at the end of the day this is a station wagon so if you think you are going to end up with some sort of R34 GTR you are mistaken.....in saying that I don't think you will ever see a Ford Territory, Falcon Station wagon or a Adventura/Commodore keeping up to one of these in the wet......and they will be battling in the dry as well.
In answer to the standard suspension on the AR-X....it's actually not to bad.....but you do feel the weight of the car......let's put it this way, it was better than the Turbo Territory and Holden Adventura I test drove when I started looking for a new car.
Edited by Jetwreck
  • 1 month later...
Thanks for the circlip suggestion - unfortunately, mine is already on the highest settings.
I will wait to see what Peddars want for their springs.
m
Got the new Peddars springs installed.
She doesn't scrape any more and retains the outstanding handling.
If anything, it has improved the turn in and the car has more tendency to over steer than the previous under steering.
Sway bars are next on the list.
Can anyone recommend someone to install them for me?
m
m
As long as you can get under the car it is easy. SK actually posted a thread on how to install them on the M35 (done on my car). It is literally an unbolt and bolt new ones back in place.
Which ones are you looking to buy. I fitted a solid 32mm front (same size as original but was hollow) and solid 24mm rear (original was 22mm hollow), it is also the adjustable one. I found that the rear needs to be on one setting harder than the front. I am thinking of backing off the front as it can still under steer on throttle at low speeds and the tuck in when you lift the throttle is a little slower than I would like.
Cheers
Andy
Cheers
Andy
I don't have access to a lift.
I have read the threads on how to, but have heard that there are some mobile mechanics who can do the job for me.
m
m
ramps would be enough, mind you I don't have those either. :LOL
may have to get some....
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
