  • Replies 91
In the lead;
89 R32 4 door
425000ish. ODO doesn't actually work though (speedo drive rooted) but thats what it shows :D
Heck man, that's an insane amount of kms regardless if the clocks stopped. Still the original motor? is it getting tired or still feels good..?
1993 R33 GTST
222,000
98 R34 GTT
121,500
Most seem to be between the 50k to 150k.
^ well, it's sorta cheating. The numbers are all screwed up (like not in line at all) so it's obviously been tampered with somehow. May or may not have something to do with the speedo drive, but yeah it's not like it did 400thou (I looked today and it was 410ish, not 425 like I thought) then stopped. I reckon the body's probably done like 160-170 thou, engine NFI :D
Haha ok, well gazza750 is still in the lead then :)
1993
r32 gtr
141 000
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
