just drive normally and youll be fine
you will only have troulbe if you load the engine up
the std service manual tells you specs for snow chains and how to fit them
id strongly advise getting a normal car for the snow however
Thanks all, I was at Hotham a couple of weeks back when it was snowing heavily and the roads were closed, but I had a mitsubushi outlander and it was a piece of piss to drive in the snow (slow speeds). Im not out to break any mountian climb records but thought it might be a nice drive and save me hiring a car again.
There is now much more variety of snow chains available with scratch protectors etc but Im keen to know if anyone has fitted any chains to their R32 GTR and wether its front or back wheels, and wether they foul on the wheel arch liner?
Cheers, Sandy.
not as obvious as you might think, lotsa new 4wds advise chains on the front wheels, is good to combat understeer aswell as traction issues, admittedly they also drive mainly from the front. Id like to know what nissan reccomend for the GTR.
Sandy
You're pacifically asking about the 32 are you?
I went up to Lake Mountain a few weeks back in my R33 GTST. There wasnt much snow on the road as most was ploughed off, it was still very slippery though. If the road is like that you should be fine without chains, just drive slow and off boost.
Lake mt to Hotham is like Mt Buller compare to Niseko Japan! I took my old 33gtst to Buller along time ago, the car is fine, just drive within your limit.
Could be a bit of overkil with chains on all 4 wheels (have to hire and fit em), does anyone know what nissan recommend for the R32 GTR?
Why dont' you ring up NISSAN themself?
Though it sounds like alot of fun, still, taking a GTR to the snow isn't the best idea as you'd imagine the Attessa System will be working over-time for sure.
unless you absoloutely had to i wouldnt do it. GT'R is about the last car i'd want to take up to the snow. heavy on fuel, bugger all room for bags, bugger all room for people inside without it turning into a fogged up sauna, and i can only imagine it would wreak havoc on the attessa system - wouldnt know what was going on!
Niseko?
Haha. I really havent been to Hotham or Buller before so I have no idea what either was like.
Just put chains on the rear wheels and take it easy. Stay in Second whenever you're on the snow/ice - even when taking off.
As soon as you've driven the first 10m with chains you'll know what you're dealing with.
I just bought some Konig chains for this season - if you get the correct size they won't scratch your rims (they barely touch them).
One thing to note however is the clearance from guards/suspension, if the car is excessively lowered or has extra wide rims forget it.
PS. Chains are very important - just ask this guy (up to Mt Baw Baw 17/08/08)
i went to bullar in my s2 stagea ... no worries didnt even bother with chains .. no slip at all .. plus the traffic i was behind, i was doin a max of about 30k's up and down ... so i dont see any reason too .. just to save money and time and have a smooth ride now a ride that feel's like you have flat tyers driving over bricks :O
I've driven the back roads from Lake Mountain to Reefton in an R31 two years ago whilst snowing
with no chains. No the most pleasant experience.
Simply kept the car in 1 and/or 2nd gear (auto) and keep the speed at 20km or less with no sudden acceleration to cause the tail to kick out or put you into an aquaplain, also or no sudden decelelarion (compression lockup) to have the tail kick out.
Same with the steering, no sudden turns, keep it smooth.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
