Chasing some info on RB26 valves, I'm in the process of a solid rebuild after lunching a ceramic turbo. Forged pistons, bearings etc, bottom end is all together.
After a quick look at the head though, the valves have been damaged.
Now, the problem, I've lurked around the internets for hours now, and searched these forums from top to bottom, including all the sponsors, nobody seems to sell valves.
I found one standard set, second hand...
What kind of valves have people used in their rebuilds, and where did you find em?
https://www.sau.com.au/forums/topic/235579-rb26-valves-for-rebuild/
naprec valves are good and cheap. I don't know who sells them in aus, I bought mine in japan, but I'm sure you can get them here too.
ive heard that the naprec valves run a smaller than standard size stem which could cause possible reliability problems in the long term with big revs..
i assume you've got the 1.5mm oversize..
so how are yours holding together and how long have they been in the car?
Another group buy coming along Andrew? (id be in :P )
F%#$K no! never getting involved in one of them again!!
i spoke to my engine builder today and it looks like i'm going to run with standard valves. tho i may still do springs and retainers.
anyone ever use super tech?
i've just ordered the full supertech catalogue (dual springs & ti retainers, guides & OS valves) from the states for a mates motor i'm building, should arrive in the next few days
prices i got were:
valves full set (1mm SS inlet, 1mm Inconel exhaust) - US$499/set
dual springs & ti retainers - US$459/set
manganese bronze guides - US$120/set
total including shipping in aussie $$'s was $1466.12
make sure the guy installing the oversize valves inserts a new valve seat as the std wont cope with the oversize valve
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
