Having a huge cleanout of 32 GTR parts. All parts are in Melb. Frieght at buyer expense. I will get sizes and weight for you but you have to price the freight up and I will confirm it once you actually want it.
Gauges and Electronics
Apexi Electronic Oil pressure and Exhaust temp gauges and senders with max warning $300 pair
HKS Vane Controller - Very Rare and wanted.
Deletes the need for afm's and can control fuel rates $500
HKS Turbo timer $80 plugs straight into dash loom
Blitz and Mines ECU's $100 each
Engine/Drivetrain
Front drive shafts (need boots) $100 pair
Rear diff and drive shafts $250
Rear drive shafts $150
Blitz external venting BOV's $175 pair or $200 with std gtr pipe to mount on.
Grex Remote Oil Filter re-locator $150
3 GTR radiators $80 each Same as gtst.
Fuel tank with hangers/pump/sender/filler neck $250
RB26dett head with hang-ons, covers, turbos $1250
Complete block, crank, pistons pumps etc $600 Original bore
Sump with diff $250
Might sell some parts of engine for right money.
R34 GTR intercooler in excellent condition $300
Suspension/Brakes
Apexi Shocks height and damper adjustable $350 not to hard-nice
Front GTR calipers and 296mm drilled disks $225
Tein HA height and damper shocks and springs $500
324mm slotted disks-new, spacer kit to run 324mm disks and overhauled calipers and braided lines with heaps of set used performance pads Upgrading to big 355mm brembo's. Best upgrade you can do without spending thousands of dollars. Almost as good as GTR brembos. Same pad width just looses 5mm on height at the bottom. No brake fade running 1.23 at Sandown and 1.52 and PI or 20 min sessions running 1.10's at Wakefield with a few laps to cool engine oil down in the middle.
Will fit R32 gtst, gtr and R33 gtst
$650
Interior
Rear seat $150
Dash board VGC $125
Dash boards. Small boubles in front of passenger $40 each
2 sets nissan floor mats $80 each
Body
RH rear quarter window $60
LH door window w/tint $40
GTR fuel cap door $50
Rear Bumper reo $60
Original Windscreen $100
Door LH complete $75 no trim
RH door $30 bare
Few mirrors $30 each
Also have a shell for sale $2000 rolling with heaps of hang ons. Has import approval under old scheme so can be complied.
Please don't ask for other stuff as this all I have. No swaps either or low ballers. I won't get back to you if you offer stupid prices. Will budge on some stuff but no others. If you know what it looks like please don't ask for pics for silly things.
Some stuff is back up for sale due to time wasters so if I told you it was sold and its relisted I still have it.
  • Replies 52
Cheers Mat. Sorry only selling the whole set. I need the money from the whole set for disks and pads for the upgrade.
Kevind but the shell and you can have the door rubber.
Bris you dirty world traveller. I can hear your car whining and howling in your garages corner like a neglected dog. Holding expecially for you.
I have the hinges for it but no internals. Hense the price. I should have a LH mirror but will need to check.
hey mate
what year is the crank from?
was after a late model for the oil pump drive issue?
cheers
No idea what year the crack is from. Its stilll in the bolck atm. What do I need to look for??? Don't really want to have to remove it as I don't have the space to store it once its apart.
Cheers Badgtr34. I'll get you the pics you requested soon. Had to remove the cover off one of the gauges to replace the globe so I need to get it back together before I take the photos.
I'll see whats involved to get the oil pump off.
hi, could i have pics (both front and rear) of the GTR intercooler? and what size is it also
Cheers
The intercooler is 60x300x600 and is very light weight compared to earlier models. They are a more efficient at cooling than the r32 and r33 gtr intercooolers. I am to believe these can cool/flow well enough to suppport upto 350ish rwkw
It a little dirty in the photo becasue it hasn't been clean since I removed it from the car a few months ago.
The diff came in a shell i bought. I removed the rear cover and the gears are in perfect condition-no spalling. There was also no metal paste sitting in the bottom of the housing. From what I can see it appears to be a very good diff that hasn't copped a hard time. The oil was very clean so I'm guessing the clutchs haven't been wearing. It turns freely with no binding.
hey buddy,
I'll come buy the rear diff and drive shafts now. Im at the shop so you can call me on 9338-5277 and we can talk details.
Regards Dave
Sorry. I cannot edit the first post. The rear diff doesn't come with the drive shafts. They are being sold seperately.
It is meant to read
Rear diff $250
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
