  • Replies 60
Here's my list:
Tein HA's
New exhaust; something slightly louder and tougher
Nice set of seats, GTR or better
...or sell up buy a real car (6 speed BA XR8 ;) )
hey mate ive got a trust cannon muffler 4 sale $30 3 1/4 inch inlet it was loud n tough sounding (just ask Ryan)
ryan......
i believe wiring, tailshaft, tune..
HILLS HILLS HILLS
Yep, pain in the arse wiring, hopefully ill finish fabricating crossmember tomorrow, tailshaft, wiring, finish off all the little things, wiring, wiring, and i think there's a little wiring left.
Oh and im gonna get a quieter exhaust with straight pipes and semi slicks.
Edited by Ryanrb25
wats wrong........hahaha u just dont wannr get defected 4 being 2 loud....
my to do list:
My RB30 Build,
25 Box + modded tail shaft + speedo drive mod
30 build-too many parts to list
GT30R + Z32 AFM + 550cc injectors
Tune her up
Some new rims possibly XD9's but atm this build is sucking me dry haha!
ah geez, i hate want to do lists..
mine would be something like this:
fix leak in clutch
ground up engine rebuild-pistons, rods, head work, cams, gears, 3071r, in and ex mani, injectors, afm, remap for responsive 250kw
i dont really know what else, once i get a bulletproof motor the car will be done..
List:
new turbo-back exhaust to fix the collapsed centre muffler + dodgy cat
steel-wheel and highflow current ceramic turbo's
remove minor dents from the car and have a full respray
get new rubber seals for the outside along the windows
interior retrim
get a head unit that actually works
brake upgrade
ah the list is huge...
Hmm...
Replace my threaded hub studs
Fit fuel Reg
Fit rb20 wastegate actuator
Install and tune PFC
decat/hi flow cat
Forward facing plenum
install catch can
paint my rocker cover
HKS 2530
fix my front bar/change to GTR front bar
get my DNA02's from japan (lukey ;) )
carbon interior
profec b spec II/Apexi AVCR
fit my 040 fuel pump
injector upgrade if need be
suspension upgrade (upper arms, lower arms, etc etc etc.)
Full rebuild, pistons, cams, rods etc etc etc
semi slicks
sway bar, rear strut brace
decent tyres
install 2JZ :)
hills ftw ;)
ive been working on my to do list for a while now and shes finally nearly done
Have already waiting to go in -
HKS Split Dump
HKS Front Pipe
Sard Torque Control Valve
Nismo engine Mounts
Blitz SBC Spec R EBC
Bosch Z32 and Plug
Slide Highflow
Tomei 3pt Strut Bace
Uras D1 SpecII Front bumper For My R33.4 Conversion
Whiteline Front swaybar
Focal Splits For The Front and Focal Coaxials for the rear
Alot of stinger wiring and sound deadening
Nismo 2 Way
HKS Timing Belt
Nismo gearknob
Apexi Super Suction Kit
Clarion CD Player And Amps
Nismo LCD Dash
Nismo 555c injectors
And theirs prolly more just cant remember it all
And The rest of stuff i need to complete her is
R34 Headlights
Uras 33.4 Fenders Side skirts and rear bar
R34 Dmax CF Bonnet
SK's Bilstein suspension kit - Coming soon
Bride Leather gradation Brix II seats - Getting them this weekend :D
Wheels - otherwise work vs kf's or volk gtc's
Respray
Double din CD/DVD/GPs unit
HKS 2835
Forged Internals
Power FC
Tomei Poncams
Epson EJ1 CPU for the LCD dash
Apex or Defi Gauges
and maybe more cant remember it all its been a big list in the works :banana:
My to-do list is pretty much complete. It just needs to be started then run in then blown up again, yay.
But yea at some point I'm gonna be converting the rear end to s13 cradle which shouldn't be too hard with a bit of fore thought, after that it's not getting any money spent on it. Famous last words.
pretty sure that LCD nismo dash wont work with your pfc Ron if you want to keep the Nismo dash you may want to look @ a remap for standard ECU chuck a VG30dett ECU in it becuase they come factory with VCT and can be remaped unlike R33 ECU
Id hope not i had a mines tuned ecu i just got rid of recently to get the pfc :banana: i always figured the dash was just the same as the standard dash with the added lcd screen in the middle as it only uses a rca input and doesn't connect to the ecu in anyway. i guess ill find out soon :D
Im pretty happy with the way my car is now but seen as tho i can't help myself i want
Dan's Plenum
Dan's turbo (if its cheap enough lol)
My own Tune
1.5 way
Suspension arms
New Coilovers
Fix my front type m lip
Ryan you may be interested in this 1.5 Way
I've got all my bits. I just need to fit them.
So my list is:
#1 wash my stagea :D
quieter muffler/cannon
fit Dolphin rear lip
shift kit and service
fit brake upgrade
wire in Apexi SAFC2 and SITC
tune and service
replace current Ohlins suspension
:banana:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
