After reading few more posts regarding this problem. Ive decided to turf out my $30 pod, possibily a oiled one and going back to the stock air box. Im certain that by going back to the stock air box our problem will disapear due to the air resude on the afm clogging our boost levels, maybe. Anyone given it a go please post results.
If not i need to take it to someone for a timing adjustment as ive heard advance it to 15+ and it should disappear.
otherwise coils packs next week, damn.
will post results.
cheers
ak
  • Replies 72
Max GT its your computer (ECU) Auto skylines have a different and more conservative program and a link to the auto trans computer that will retard ignition timing sooner than a manual and perform a fuel cut sooner at higher boost levels. This has been a big problem for me for 12 months! Anyway I bit the bullet and tried a modified manual computer.... and YEAH BABY YEAH!! now i'm running 1 bar boost and have to be careful changing to second because there is no rev cut now so savage gear changes are all the go. Also if your going to try this, then make sure to get a dyno tune afterwards to be sure.
Strich9ine i don't know if this helps buddy but if your car is a manual and a series 2 and you want some split fire coil packs then drop J-SPEC a line. [email protected] They have a new set collecting dust in the office! it also wouldn't hurt to try a mates ECU. the ecu in mine caused all sorts of problems in the previous car and we tried every thing to no avail just to find that it was the ECU. Hope this helps guys. Have a nice day. :(
well im not sure about that website above but im gona buy some injector cleaner whatever is expensive and see what happens maybe a clogged injector could be the cause but most likely its the coils.
does anyone know where the vvt thing is?
cheers
ak
ive got a gts pillarless r31, runin the niccs rb20det and im havin the same prob! as son as i put the new 3 inche exhaust form turbo , i was get missfires at about 4-6 grand, very anoying at times! ill try cleaning injectors, getin a full tune up, and adjustment of the afm, hopefuly i fix the prob =/
sky^rkt
Chances are that your ECU is responsible for the missfire, when you fitted the exhaust you removed a restriction from your engine allowing it to boost more, the factory ECU could be retarding your timing and or cutting your fuel, you may also find the problem to be more pronounced when the air is cold in the morning or at night. Are you still running stock boost?
Well, after your tune you'll have more of an idea of what it isn't. these things are usually not fixed easily, the more information you can give about the conditions when the missfire happens the better. Also, nissans run different parameters when the engine is cold, this is to protect the engine. you should avoid caning until the temp gauge reaches normal operating temperature. I found i had less missfiring problems when the engine was cold but when the engine warmed up and the air was cold outside misfiring was more pronounced. Good luck
yeh, i was told just to try it when it was cold to see if it wuld happen and it didnt, i always let the car warm up to opertating temp, probably in the next week or so ill get a full service of everythign and see what hapens form there, i appreciate the help guys thanx heaps!
My nics has a simular problem it tends to misfire & be laggy while cruising when cold, as soon as the motor warms up and the temp needle hits the fist line on the gauge it takes off and is fine. I have, changed ECU temp censor, O2 Sensor, just had the AFM Calibrated wich fixed my over fueling problem as some one had dicked with it and was way out. I have just replaced my ECU and it seems to not be laggy when cold but splutters a bit more when cold but can put that down to still learning. this has been a quest over the last 12 months and will not be happy until it purs.
Well guys told you i would keep you posted on the remedy for our poping in RB25s. Ive been told possible problems coils, ignitor module, pod etc. Well i went to autobarn in my area(sunshine), ask the guy if he had a really good injector cleaner thinking i might have an injector problem. Well he said try Pro Strength Octane Booster (NULON) for $20. The reason he told me was it cleans the bad deposits on the injectors, increases performances and horsepower. Well once the octane boost kicked in any car on the road will have no chance. It holds boost and keeps on boosting.
Hope it fixes your guys problem, fixed mine; touch wood.
Cheers
AK
Another interesting point is that japanese fuel is better octane than any aussie fuel, so an octane booster may fix the problem but if it comes back next tank of fuel then altering the timing, as has been suggested, would be a better long term solution.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
