Were they run on the same dyno??
Yes, exact same dyno. Dyno Dynamics in Shootout mode.
and the 468rwkw one has run 132mph.
Can you post sheets please? Will help a lot of people decide if the HKS turbo is worth the 2k more...
  • Replies 58
dirt can you post up bp98 tune as well because i want to see comparison of hks t04z with garrett t04z on same fuel
mine made 428rwkw on 24psi (garrett) and another has made 468rwkw on 25psi (garrett). both were standard stroke 2.6l's
is this a 2.6l?
Yes still 2.6 & it made 422rwkw on 22psi & was on synergy8000.
my hks t04z has gone 585rwhp (440rwkw from my calculation) on 18psi on 98 pump fuel on a very very low reading dyno, another brand new dyno dynamics one i went on recently read 40hp more (520hp to 560hp) on lower boost tune, so i reckon it would of been a bit over 600rwhp on any other dyno.
brad!!!
clearly you should know you had about 150rwhp of timing in that tune to make that power
PING IS POWER
actually it was a different dyno i think, cause my car was tuned on the new 4wd dyno (in 2wd) and chookos was on the old 2wd one
chookos made 454rwkw or 608rwhp with similar tune to mine, but made more with cam timing and further tuning. my cams never got moved from zero so may have been a little more in it!
same tuner, same workshop, same fuel and very similar engines etc etc
ok, could my standard valve springs and 260 poncams be limiting my power on 24 psi with a t04z to 376awkw (.84 split a/r ex housing)..???
Just a little bit, Dave. :bunny:
PS, I'm still waiting!
interesting for me, that youve only run 132mph with 460rwkw. Ive seen an r32 gtr with 360rwkw go 134mph @ 10.8
brad!!!
PING IS POWER
lol Simon, he has never done a power tune on my car only a run in tune on the first motor years ago ;) everyone knows he wont touch an autronic ecu hence why i never used him in the end.
Edited by unique1
Simon's time (10.91 @ 132 with 460rwkw) was with a stock gearbox and $90 shitty tyres.
At 3256lbs (std 32 GTR weight) and 485hp (360rwkw) you shouldn't be running 134mph, more like 124mph.
Can I ask what turbo was used?
Let me guess, it's a 700+hp rated turbo, running in its peak efficiency, and "only" making 485hp at the treads. I'd suspect a very low reading dyno....
Besides the point, all I want to see is a compo between a HKS T04Z and Garrett version, someone post dyno's!!
something im struggling to believe unless it was a super low weighted car with a dog-box on slicks and with that ET i doubt it.
134MPH = at the very least 400AWKW in a R32 GTR
im pretty sure he ran around 134mph on another pass...
he was also running standard box so change from 2nd to 3rd was slower than leasurely which would have dropped the mph a fair bit i would imagine.
GRRRRRRRRRRRAAAAAAAAAAAPPPPPPPPPHHHHHHHHHHHHHHHHHHHSSSSSSSSSSSS
r32 gtr, os giken gear set, hks t51r. Not sure if it was lightended, il have to ask him next time i see him.
another r32 gtr with n1's went hi 11s @ 125mph, he had just over 300rwkw. Wasnt a fancy set up either.
My boat did 139.67mph with 456 rwkw although only 10.70 with 1.57 best 60 foot. It had 540 pound springs at the time in rear, yes way too hard and wouldn't weight transfer, and front diff not there.
PS Good power Dave and good result. PPG helical dog box would have less power drain I guess over stock synchro box??
Edited by Boosted Zed
LOL
HKS T51R... SPL or KAI? Either way its a ~900hp rated turbo, and you reckon it only makes 450rwhp.
Either it's being transfered through a rubber driveline or it's running 14psi.
As I said, thats one hell of a low reading dyno. It's physically not possible for a car that weighs as much as a GT-R to do ~135mph with 450rwhp.
No they would be about the same...the gears are the same basic design albeit a more agressive tooth profile and far superior parent material on the PPG. The way each gear is selected whether it be dog engagement or synchromesh has little bearing on the losses after the gear is selected.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
