Morwell - Sat 11 Oct - Sau Vic Club C/ship - Rnd 7
  • Replies 68
Yeah what a great event! cheap, easy on the car, well run and a real challenge. i've seen the large freak's photos, hoping someone caught me when i had the fuel spraying out the filler neck (gotta remember to put those things back on!) are pics going in this forum or a different spot? thebuzz, i was meaning to come over and say hi, how's your datto going?
Great pics mate, thanks for posting them up.
Lagwagon, haven't done much with the Datsun lately, been doing heaps with the GT-R instead, haven't driven it for a few months... Might try and give it a run in the evening sometime soon now that daylight savings is here. Would have been a bit of fun out there yesterday hehe
What a top day.....best $75 I've spent in a while :)
Well where do I start.....a big thank you to the organizers and volunteers of the event as it was very well run. There was a fair wait in between runs but that was a reflection of the quantity of cars rather than the runnings of the day as there were 70odd cars there.
It was my first time at the new morwell hillclimb and I must say that it looked a little daunting from the carpark...tight, technical in parts and huge elevation changes. I had heard the stories of cars having stacks on it and when I was introduced to 'oh sh1t' corner it all made sense and the tyre scars on the grass confirmed the stories :0 Despite this and the fact that something like an evo or well sorted wrx has the upper hand here the track proved to be a great place to hussle a GTR around :)
I started off taking it fairly easy with a first run of 1:04something but I was able to knock time off every pass with my last run resulting in a best of 58.50. Here are a couple of incar vids:
This is my 1:00.07 pass with a good drift moment 2 corners after 'oh sh1t':
1:00.07
This is my next pass at 59.51:
59.51
and the last one I captured (vid battery died for my run after this) with a little off track excursion ;) which resulted in a 58.68:
58.68
I did a 58.50 in my last run without the little off track excursion but I do feel that there is more time to be found esp if you have adjustable suspn.
Also thanks to Ryan (Belsil80) without our little battle in the arvo I doubt we would've pushed ourselves to get the times we did (check the results to see how close we were pass after pass) but you should've known that the GTR would neva loose in the end :(
Good pics so far big bird but I want to see some sideways action ;)
agh I had to pull out due to illness, then proceeded to cut my hand open washing dishes yesterday needing 5 stitches... what a weekend
ah well there is always next year, good work on the times Ryan and Ant, very impressed
the pics are making me depressed, looks like a beautiful day/track for some fanging
It was a great day, though I'm absolutely fried... first day in the sun has taken it's toll!
Great track though, can't wait to get the 180 out onto it. Will definately give me more confidence knowing I don't have to drive it to work on Monday :P
Top shots as well Jarrod, nice one.
Nick: Nasty weekend for you mate!
Kids, there is 97 in the gallery so far. here's something i prepared earlier.
And here are the pics that i have put up.
when a massive wing isnt enough, get police strobes.....
2 wheelin dave.
dont forget to blow some hot air up my arse!
http://www.flickr.com/photos/25681729@N08/...57607956799021/
cheers!!!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
