And I've actually heard from a friend who did that setup on his VS V8 commy that it can be beneficial as the air that passes through the turbo is alot cooler when it goes through since its got that extra distance to travel. Not too sure on the validity of this point but it kinda makes sense...
How does it defeat the purpose? The car is still turbocharged...
well, the idea of a turbo charger and heat, is so the exhaust gases are hot and "excited" and spool the turbine a lot faster than the much cooler low flow of air at the back of the car.
The response out of one of those setups would be terrible. Plus they have a hell of a lot more pipe distance to cause leak problems.
  • Replies 52
Im buying a 6boost manifold atm with a gt35R (0.82) atm and will be expecting full boost around 4300, a little laggy for the rb25 but i am planning to convert to a rb30 down the track so its not a bad option, if you want in a few weeks when its installed up i'll let you know how it is on the street
Ive read everyones comments, aswell as researched the idea and the conclusion will be
a.] GT3540R w/ 0.82
or
b.] GT3037R w/ 0.63
ive read alot about these turbos on different setups and depending on what Im gonna pursue ill will pick the turbo that will suit it.
It'll only leak at the joins but every car has that.
As for the cooler air flow causing lag, we're talking about mostly V8's that do this setup not skylines. Obviously its dumb to set it up on a skyline but you wouldn't need to. A big v8 needs the lag so it doesn't smash tyres. Get the v8 going then boost, can't beat that.
None of that makes any sense at all
I has a dream!!
Im gonna buy a stock turbo and replace my rear muffler with it!!
Rb25dett baby yeah!!!
would surely make 11ty million killer wasps at 35rpm and then ill use one of those ebay electric superchargers to really get it going down low
*imagines pipe work needed to run a single AFM with a turbo in the stock spot, one at the rear, 2 intercoolers while using PVC for piping*
Do you think Ill win a Engineering award at Autosalon?
P.s Im not drunk
:cool:
Btw, Ive concucted a flange to attack my Stock RB25 turbo to my ride on mower , ill be using a custom intercooler w/ no BoV, hopefully producing some mower dose action. I got the idea of a Youtube vid of a guy doin it, should be fun. I hope i dont blow up the engine as its gonna be 100% FF.
I love the fact that that a guy with the initial thought that he would high mount a stock turbo thinks he has the skill / money to turbo his ride on with a custom cooler!!! ahahaha
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
