One Car Needed For Mothers Stand @ Auto Salon
As the title suggests, im looking for ONE car that is modified and pretty much with a perfect paint job to be a part of the Mothers Stand at this years Auto Salon
It obviously needs to have a pretty perfect paint job, and be preferably modified
It doesnt cost you anything as mothers will pay for your car to be and it will be detailed during the time its @ the show :)
Send me some photos and ill pick the best looking one :)
Thanks guys
Matty
hahahah
come past and ill hook u up with whatever man :(
im suprised with the low amount of interest.. i thought ppl would jump @ the chance to have thier car in the auto salon for free and detailed by hot chicks lol
weird :D if only i could finish my fkn car in time.. oh wellz
Im not surprised that much... :(
Most people already have organised their cars with other stands (if they were interested in going etc) being entires for club style things usually are worked out a month/two ago :D
Lots of discussion for SAU and others was all done about 3 months ago i think?
Im not surprised that much... :banana:
Most people already have organised their cars with other stands (if they were interested in going etc) being entires for club style things usually are worked out a month/two ago :)
sent PM if you still lookin for someone
cheers
hahahah
come past and ill hook u up with whatever man :P
will you be at the stand? or sell it outside of autosalon?
Im sure everyone would love to see a banged up dirty r32 turn into magic with the use of mothers products :banana:
is this still on offer , i have a r34 , painted in the anodized purple , choise of work wheels or volk ! , just dynod yesterday at status tunning at 1001.5 hp at the wheels ,have dyno sheets to show , willing to show the crowd the raw power of a rb 26 engine , pm me , if your keen to much to mention,must see here in melb , built by Oh performance in sunshine just one of the monsters, on offer
Edited by turbo rxp
hahah sounds like what im building right now :)
Yes the offer still stands.. ill let everyone know when i have found the car of my choice.. until i say ive found one.. its still on
And yes ill be on the stand as well as everywhere else, and yes also.. i sell mothers products but im not a mothers Rep or anything.
Just good friends with the state manager and the performance manager of Autobarn Melbourne :blink:
Yes i understand Nismoid that this shouldve been organised awhile ago, BUT as it turns out.. my engine hasnt been completed yet.. It will be done by next week.. leaving not enough time to have it ready at all.. but ill try have it up @ the sydney finals :ninja:
Keep the pm's comin through guys, not much time left
people might not be 'jumping at the chance' as much because we have FI in town, we have been "informed" ;)
if you said, "i need a car for the Menzerna stand..." it would be hands up from me! :D
and pictures of the 1000hp 34!! anodized purple?? need to see this!
The purple R34 gtt with rb26 is certainly an impressive machine.. Saw it last night. used to be orange, the old motor built by RK reckless tuning in Japan. Looking forward to see it on the dyno. Sounds angrryyyy ;)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
