Hey guys, My Climate Control on the R34 stopped Illuminating itself. Im guessing that the bulb inside has decided to take a break lol.
Any info i can get on changing it ? Because it makes it a hell-a-lot hard to navigate when im driving at night and try to use the Air Con etc etc.
I only just noticed it last night lol! When the hazard button wasnt illuminated.
Cheers in advanced !!
MRXTCZ
P.S I think 666DAN has some gear to sell, but i dont know how to install it.
https://www.sau.com.au/forums/topic/237207-r34-climate-control-panel/
1. pop off your aircon vents (using flat head screwdriver and a cloth)
2. take out ashtray and undo the screw under it
3. pop off your gear surround (using flat head and cloth near handbrake)
4. under four screws (two top, two bottom, to remove the entire center console including climate control panel)
5. take off the four screws (some only have two) holding the climate control panel together.
6. disconnect the two plugs connecting the climate control panel.
7. you'll notice that there are several 'levers' to open climate control panel itself... i use a guitar pick (or three) to open without breaking any levers.
8. you'll find three twist type bulb holders. twist them to remove.
9. insert new bulbs (t10 i think, not sure though). Or make some new led ones up, by pushing the legs through the two little holes in the bulb holder.
10. check to see if they light up. when it's all back together.
reverse process to install again.
Hope that helps.
Cheers man that was great!
Will try this arvo when i get back, need to get those T10 bulbs though, im guessing their the same for the Dash aswell.
You wouldnt know how to dismantle the dash to get to the bulbs would you :thumbsup: ?
MRXTCZ
Np's man. Dash are T5's I think... the climate control are smaller. Although you can modify the T5 led's dan sells to fit the climate control panel by bending out the legs and sticking them in.
To dismantle the dash..
1. remove the bezel around the dash cluster.
2. unscrew the four screws (two top and two bottom i think).
3. drop the steering wheel to it's lowest point.
4. slowly pull towards the cluster towards you.
5. with your hands, reach in from behind and unclip the 3 or 4 looms connecting itself to the cluster.
6. with all looms disconnected from the cluster, try to pull left (in between the steering wheel) to remove.
7. replace all the appropriate bulbs (make sure they work, as led's have polarity).
reverse to reinstall.
  • 2 months later...
  • 9 months later...
my aircon button lights stopt working, i opended it up, seems they are blown, i took the bulb to autobarn, they said they dont sell them , where can i find them? are they t5 or t10
  • 4 months later...
  • 4 years later...
  • 4 weeks later...
  • 1 year later...
sorry to dig up an old thread. I am based out in the UK and have the same problem and would like to replace my blown bulbs but would like to install the original colour back in. Also i have tried to take the blue plastic cap off the blown bulb and have not been able to do this successfully as it seems the blue cap has been caked onto the bulb from continuous use and age. If someone knows the part number for the original part i would rather prefer that. Any help would be much appreciated. Thank you
Edited by bhp
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
