hi guys, just need some info. have just purchased a 32gtr and it was running rwd as it had broke the standard front shafts.
now i have purchased the front shafts but need to know if there is supposed to be a spring o-ring or a circlip in the position on the pic attached.
thanks adam
https://www.sau.com.au/forums/topic/237955-gtr-experts-need-some-info/
i know this is prolly a lil annoying but i like to know what im doin b4 i start... will i find the circlip just in the bottom of the casing or will it be cought up in something. also is there supposed to be a gasket on the housing or will it be purely sealent only and tolerence fitment. and finally what should i be refilling the transfer case with as this is the first time i have had to deal with the gtr system... thanks for your help mate.
so i took the diff cover off and found the remanance of what looks like a spring o-ring (thought id find a circlip??) just need to know if this is what locks the shaft in place. any answers would be appriciated as i need to send my wife over tomorrow to the local cv shop to get one
thanks adam
Yes, the spring o ring is it, as for the diff oil I use Red Line Lightweight Shockproof with no issues, its not cheap though and there are other options out there, best to call a workshop on that one. No there is no gasket on the cover, just the sealant.
Ok, might be wrong here, but I thought the circlip lived in the diff. That's why the shaft has a chamfer on the end - so the circlip can slide up and over the shaft and pop down into the groove.
Yes thats right, the shaft slides in the diff and gets locked in place by that circlip which sits on the end of the shaft inside the diff
hey mate a lil confused, these two statements kinda contradict each other... is it a circlip that is located in the spline inside the diff center (thats what old mate at the cv shop said today... or is it that spring o-ring that i found the remainds of last night (the guy at the CV shop said that it was more likly to be from the seal that shaft goes through.)
Had em out a couple o times. The spring clip compresses in the groove of the spline as the spline is taken out of the diff, it is supposed to stay in the grooved part of spline. Then it springs back out a little once out of the diff.
It would of come off the spline due to it being: worn, stretched out or bent or just by chance it got pushed off instead of compressing upon removal.
Anyone confused at my explanation :P I'm going to bed!
I just went through this myself... I just fully rebuilt both inner and outer
cv's and came across the same problem.
I'm glad someone found out for sure that the circlip is on the shaft.... I put mine back in without a circlip... I was told alot of people do with no problems. Its not like with the
cv bolted and locked in place a Circlip is going to make much of a difference right? ....
Also what is the capacity of the front diff? 1L? also where do you get your redline? cost?
I was going to go for the motul gear oil.
cheers
rob
  • 1 year later...
mother fu**er lol
i took my sump and shaft to a "reputable" workshop
they said the circlip was supposed to stay on the shaft. so they pulled the diff apart and took the circlip out.
the sump is back on the engine and the engine is back in the car. i tried to insert the shaft into the diff but it wouldnt go in. the circlip stops the shaft from going in.
its now ridiculously obvious that the circlip is supposed to stay in the diff.
they charged me $80 to remove the circlip.
i have the receipt. but how do i go about getting the cir clip put back into my diff? as i said the sump + diff is back on the car. and the only way i see the cir clip going back in is if i take the engine out and pull the diff apart.
should the workshop fix my problem?
is it ok if i put the shaft in without the circlip?
thanks
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
