Hi Guys,
I recently got my car resprayed, bodykit re-glassed, and i also got some other little custom things done, one of these things included shaving the boot. This included; rear wing, boot brake light, Nissan badge & boot lock.
I've also had my tail lights re-wired so that all four 'rings' light up on the brake, instead of just two, as per a stock R34. Pictures attached, I hope you guys enjoy & appreciate.
(Pictures taken on camera phone, sorry for low quality).
https://www.sau.com.au/forums/topic/237975-r34-boot-shaved/
Looks good man, best way to do it.
How did you wire up the lights? I've got some mates who might be interested
I'll upload some pictures and so fourth on the lights tomorrow hopefully, will keep you posted.
I shaved the S off the bonnet too, only badges that are kept are the GT badges on the side.
Ganador mirrors comming soon too, and some bronze Work Emotion XD9's for my car, hopefully it suits the dark blue pearl colour of my car. :)
https://www.sau.com.au/forums/topic/237975-r34-boot-shaved/#findComment-4161531
looks brilliant bud, is there any issues with removing the bootlid light? im gettin a little rust around there now, and since seeing how nicely yours turned up im thinking of removing mine too when respraying the lid.
https://www.sau.com.au/forums/topic/237975-r34-boot-shaved/#findComment-4162856
No issues at all, mine also had a tiny bit of rust, it's a common issue in R34's. Legally speaking I think you have to have one there, but i just passed a roadworthy with it, so who cares.
To make all four rear tail lights to light up you need to add 2 globes to each light and wire them up to the brake light, piss easy and costs f**k all to do it.
Lucky beauty is in the eye of the beholder Gathem, i love my genuine cwest kit. :nyaanyaa:
I also just added 3 autometer gauges in the triple gauge cluster, and one which is in place of the cigarette lighter, looks mint, i'll post up pictures later this week. Because the gauges were a tiny bit smaller than the gauge holder (about 1.5mm) i got a peice of aluminium, had it painted matte black and then mounted them into the centre of that, also getting rid of the glass that is in front of the stock gauges, also installed a new mongoose alarm which works in conjuction with my factory central locking key, greddy turbo timer mounted flush with the dash, just above the sunglasses holder for those who know where i'm talking about.
Next is R34 GTR seats, 10" subwoofer and an amp, all hidden so you cant see a thing. My attention to detail is stupidly insane almost, but perfection and a clean look is what i'm after, it'll all be worth it in the end. Also plan to spray the centre console and window switches in the same colour, or maybe silver, undecided yet.
https://www.sau.com.au/forums/topic/237975-r34-boot-shaved/#findComment-4163688
Lucky beauty is in the eye of the beholder Gathem, i love my genuine cwest kit. :D
Sounds awesome dude, lookin forward to more pics, u say u have a greddy TT, is it the full auto timer? if so did you get a harness to go with it or just splice wires? I want the full auto timer, but am not sure which harness will go with the 34, hard to find info on it
https://www.sau.com.au/forums/topic/237975-r34-boot-shaved/#findComment-4164372
Yeah, i've got the full auto timer, intergrated into my mongoose alarm.
I didn't get the optional harness, just slpiced, solder & tape up. It's a great turbo timer, although i highly doubt i'm going to use any other of the features like 0 - 200m times and so fourth. No need to really purchase the harness, took all of 25 minutes to install with the splice method. Good luck, and i'll upload more pictures soon. :)
https://www.sau.com.au/forums/topic/237975-r34-boot-shaved/#findComment-4165434
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
