G'day,
I've posted a new topic as a last resort....
Details: 89 r32 GTR, Just put my re-built engine back into my GTR along with a new sigle turbo setup. (removed complete aircon components aswel)
Problem: i have no spark.
Can you guys help me track down the promblem... help me back track starting from the spark plugs, it could be just a plug off somewhere, i have spent five hours looking at plugs...there are a couple plugs i can't find a homes for either, one being a 2 pin plug that comes out the back of the injector plug loom...its short and doesn't reach anywhere.
any help would be geat guys. cheers.
  • Replies 43
Posted Images
Do you have injector pulse?
not sure, but the plugs are getting wet, just checked the coilpack plug wires and i have earth and then when i connect the test light to the positive side of the coilpack plug and wind the engine over the light flashes...
......... New Problem, got 2 good batteries, but the egine cranks over like the batterys flat....????? winds over real slow ???
HELP....... :D
You need to find out if the injectors are pulsing if they aren't, its CAS (Crank Angle Sensor)
there is nothing wrong with the cas. i went through all that just incase.
the issue is i have no spark... injecors are fine... spark is the issue. i can visually see that the sparkplugs arn't creating a spark.
but before i can continue with fixing that..i need to work out why the engine has started cranking over so slowly... any help would be greatly appreciated.
did u ever think ur module may be sending through a weak signal but just enough to give a blip on the test light. remember test lights dont take much to glow. check all ur earths properly and just make sure they are getting a decent surface to earth to. double check also u connected earth wire to the coilpacks down the back. cant hurt to suggest a couple of little things. or at a long shot check fuses in boot underdash and interior.....
also mate engine temp sensor or coolant temperature sensors are vital to wat the computer gets told so if its faulty replace it or it will run like a sack.
Edited by skylinekid
well you said you weren't sure if you had injector pulse...
dont shoot me, im just going off what you say.
all help appreciated, just trying to sort out the spark problem, as i know that its not getting any.. and the slow cranking is odd also.... its stopping me fixing the spark issue...
i need help with the slow cranking
the slow cranking may be ur starter motor giving up the ghost... im no electrician but check that the power wire to the starter is bolted down correctly and the lil (exciter wire) is still plugged one properly. short of that it could possibly be an internal problem. how long have u been trying to start it for
Have you got oil pressure? (I know it's not your problem, but you want oil pressure before you get the spark working).
Is the igniter properly earthed? Have you tried a different igniter?
Have you got a good block->chassis earth connection?
Yeah, definately check your oil pressure and make sure its is up before you fire it up - could be why its is not turning over real easy, lack of lubrication. This is just safe-guard to ensure everything has oil (and that the oil pump has been assembled correctly!) Know this may sound obvious but have you checked your ignition fuse(s) maybe blewn when re-connecting everything?
Good Luck - you will get it going and I bet it's something easy - always has been for me anyhow.
Ok,
Fixed cranking problem,
Oil pressure is good
just need to sort the spark problem...
i have a multi-meter but have no clue how to use it....lol.. also have a service manual to tell me how to check the whole ignition system but..(still not sure what readings and values i should be getting on the multimeter? any help there? :blush:
also i have one plug i need to find a home for, ill just go get a picture of it and post up... if someone could run out to their gtr and have a look where it goes that would be tops.
thanks guys
Picture:
blue circle is the plastic cover that the injector plug wires run through
Red is the 2 pin plug that needs a home
and the green circle is the loom it comes from
this plug may not need a home, but im not sure.
any help appreciated.
hey mate think i solved ur problem.... u are missing this.. it sits at the base of ur injector loom....
has a white and a black wire. doesnt lead newhere just goes straight in and straight back out. aka resistor
it has printed on it 0.47 a funny u shape and and f. good luck buddy. :P
sum more good news after i just had a quick look is that black wire runs to the module harness clip its actually the earth wire. id say thats ur issue.
sum more good news after i just had a quick look is that black wire runs to the module harness clip. id say thats ur issue
aaaahhhh,
and this plugs onto the plug i mentioned?
does it mount somewhere?
it was taped onto the side of the harness buddy. so no even zip tie it doesnt really matter. ive just got a spare harness lieing on my computer room floor so just thought id have a peak lol
so you're saying it pluged onto that plug i showed?
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
