I need a new exhaust manifold gasket and the studs/bolts for the RB25DET.
Does anyone know where to get one from ? are they the same as the RB30 ?
Also, what about the studs/bolts ?
If anyone could point me in the right direction ie. Part numbers etc (can i get these at my local repco?)
Thanks guys ;)
In Sydney i got the gasket and all new studs from Nissan (there are 3 Nissan dealers to the best of my knowledge in Sydney flogging new Nissan import parts)
The Nissan studs are mild steel jobbies. If you can get an R33 stud go to someone like Hobson Fasteners and gets some nice High Tensile Studs (i will be if the manifold ever comes off again)
nissan hornsby are very helpfull guys , i have dealt with them a number of times , as for prices they are all simmilar although i get trade prices . most nissan dealers will do imports now .
joel i can assure u the break very easy cause people overtighten them ( u must use a torque rench ) and they get brittle cause they get very hot then cool down and again and again , its very common with the skyline ( broken exhaut manifold studs )
Roy:
I understand the standard studs break rather easily however if you seek aftermarket hight tensile studs these shouldn't break.
hi, i had some exhaust studs break too.
They were number 5 & 6 cylinders. They are a real bugger to drill out whilst the motor is in place. I was quoted about $600 to do it, so I bought the studs and washers and gasket from nissan for about$150 and hired a 90 degree drill($20) and replaced the studs with the help of my dad- took the best part of a Saturday - dismantling, drilling, fitting studs and reinstalling everything.
I used some really unusual screw extractors (looks like a rod with about 8 ridges running down the length of the extractor - some german brand), 'just drill ahole in the centre of stud' and bang them in and twist - was quite easy to extract them BUT not easy to drill!, tip... leave exhaust manifold on if you can to help guide the drill, save slipping off and drilling the soft aluminium.
I'm glad bolts were mild steel, very easy to slip off centre with drill. I agree with the person who said the high tensile ones go brittle and can break too, there is alot of weight hanging off them (turbo and front of exhaust system).My mild steel bolts lasted about 12 years.
Stephen
stephen , the tools u use to extract the studs are called easyout. u must drill the right size hole it tells u on the easyout bit put the easyout in the hole turn anticlockwise and out she comes .
u 'll find if u dont touch these studs they wont break but when people take manifold off they usualy do them to tight so they break soon after . dont forget that they get very hot and then cold so they become brittle too.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
