Finally after a long wait my car is back on the road and sorted out, for now....
Just about done with things i wanna do. Just a few more little things.
Then new turbos next year...
Then i hope im all done for awhile!
Exhaust:
Kakimoto Catback Exhaust, front pipe, high flow cat
Suspension:
New blisten Shocks, Lowered King Springs
Wheels:
Work XD9s 18 x 10 +18 with Kumo 275s all round
Modifications:
700cc SARD injectors
TOMEI cam gears
HKS pods
Custom Cold Air Intake
Trust Intercooler
Nismo Fuel Pump
Power Fc and Controller
Greedy Profec 2 Boost Controller
Twin Plate Clutch
HKS boost gauge
Resprayed Brembo brakes
Clear front and side indicators
Carbon Wing Blade
Carbon GTR End Caps
Stereo Audio / Visual: Sony Tv/Dvd In dash, 2 Kicker 10" subs, Kicker Mono black class D amp, Kicker 4 channel amp, 2 sets of kicker splits and tweeters
Power: 269kws at all for wheels
https://www.sau.com.au/forums/topic/238567-my-gtr-33/
Thanks Damo.... Im not a huge fan of photoing midnight Purple, it comes out to black. I think it looks better in real life.
Jase, I did some and boostworks did the other.. But i painted the calapiers and brembo, pods, cold air intake etc... Was off the road for a month or two by the time all the work was done and it was wheel aligned with the new wheels.
Again have nothing bad to say about boostworks!! Top guys down there!!
https://www.sau.com.au/forums/topic/238567-my-gtr-33/#findComment-4170026
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
