hi guys,
last night for the 1st time i could smell an unusual burning under the bonnet & noticed a very slight bit of smoke - i checked it out as i put the car on ramps & noticed that there is a very slight & slooow oil drip from the bottom of the rear turbine housing (hks gtss setup) & the oil actually drips on the exhaust header hence the bad smell...
even if i look at the front turbine there is a little bit of oil on the bottom of that turbine as well which is relatively common as i also had this on my previous gtr. my mechanic also advised this is nothing unusual on a gtr.
what really bothers me is not the pissy little leak BUT the oil drips on the header & the stench is not good - what could this be (oil seal in the turbine itself)? has anyone else had a similar problem?
regards.
marko
good starting point - are the cam cover gaskets rubber & reusable 'if' they are not cracked or broken?
if it is this problem i can probably use gasket sealant to fix this
don't use sealant, you'll only make the leak worse.
Replace them.
The oil at the front of the turbo is likely to be coming from the rocker cover breather that vents back into the pipe on the intake. Fit a decent catch can to eliminate this. Oil from the turbine housing could be an oil seal but is probably coming from the oil feed etc. as stated above. Have it checked out or clean it down and check it again in a couple of days. You be able to see where the leak comes from easier that way.
hi guys,
here is the latest update: i had my mechanic look at my car today on the hoist & he said that this is 'blow by' which is common with most gtr's which he has seen in the past, both turbos are actually leaking from the back of the turbo housing.
reason for this - you get a build up of oil in the intercooler plumbing which eventually is pushed through the turbos hence it then leaks through the housing with pressure & heat. i did notice the oil in these pipes, question is how does the oil end up in the intercooler plumbing?
ok i will block off the breather that runs from the rocker cover to the intake pipe. do i also need to clean out the oil that has collected in my plumbing & intercooler or will this continue to blow out over time?
if i look at the way i installed my catch can, i have fitted the catch can hoses to the rocker cover fittings which are pointing toward the front of the car & the driver side rocker cover fitting which points to the right wheel is still connected as per factory with the black hose - i assume i dont need to alter these fittings as well?
What? How does oil from blow-by end up dripping off the rear housings???
it makes sense - i am running a catch can to collect blow by but i did not block off the plumbing that runs between the rocker cover & intake pipe which is between the air filter & turbo, the way i had it setup meant that whenever i'd push the car the blow by on the exhaust side would be split with 50% going to the catch can & the other 50% going into my intake pipe which in fact plumbs to my leaking rear turbo. when i took this pipe off it was full of oil.
the reason it leaks out of the turbo housing is because it is designed to take oil from the intake opening thus leaks from the housing
through the rocker cover breather pipe as mentioned above
i have blocked off the breather pipe & took the car for another drive after wiping down the front pipe from the leaking oil - there was oil still dripping onto the front pipe but it didnt appear to be as much...this must be the left over oil in the turbo housing, how long should it take for the remaining oil in the housing to be expelled?
You need to make sure the crankcase can actually vent. Does the catch can have a filter on it? If not, then don't block that fitting as the engine will build up pressure and pop the dipstick out or blow an oil seal somewhere or it can make the turbos leak from the seals.
Primary objective is to let the breathers vent to a neutral pressure system. If you have two of the breathers going to a can that has no vent filter, the one that points to the passenger wheel is blocked and the one that points to the driver's wheel goes to the PCV Valve, then the crankcase cannot expel the pressure build up so it will escape another way....a more undesirable way.
yes, my catch can does have a filter so it can vent to atmosphere, i have blocked off the breather plumbing between the rocker cover & intake pipe...im just wondering how long it should take for the remaining oil in the turbine housing to be expelled out, what are your thoughts?
I would expect a week at most.
You can detach the pipe and clean it out if you want. That oughta sort it out.
you realise the oil has to pass through two seals and run along the shaft to pass from the compressor cover to the turbine housing. sounds like wishfull thinking too me.
You should also be aware that you need to sufficiently vent the crank case, just because you have one breather does not mean that it is venting enough. You may still get a pressure build up.
And the pressure usually goes out the easiest route (turbo seals etc)...
Personally I would clean and dry your intake / intercooler piping / intercooler. And let it dry properly.
:P
i have removed & cleaned the intake pipe for the rear turbo, is this the pipe you are referring to cleaning out?
btw this intake pipe was filthy, it had pools of oil in the rib lining & when i slipped it off the front of the turbo oil oozed out of the opening & also had a puddle of oil at the bottom of the turbo intake - i can see how the breather hose was the issue here
I'm not sure if anyone else noticed it but if you read his first post he mentions the rear turbine housing. But if you think about it, the turbine housing is going to be just as hot, if not hotter, than the manifold. I don't see how the oil could run along the turbine housing, drip onto the manifold, then burn on the manifold. It would be burning on the turbine housing before it even dripped.
That is why I deduced that he was actually referring to the compressor cover but called it a turbine housing.
I could be way off though.
i blocked off the rocker cover plumbing but with a crap bung which started to leak when i was driving toward the cbd & the amount of smoke was scary to say the least & embarrassing (so i could only imagine how much oil was forced into the intake pipe with the original plumbing setup)
i then bought a hose end cap & did this properly & since it is still leaking from the turbo onto the front pipe but no where near as much - i may need to pull out the entire plumbing & intercooler to clean out the oil if it keeps dripping the way it is...maybe i just need to give it a bit more time until the oil eventually dissipates from the plumbing - any thoughts here guys?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
