  • Replies 71
f**k, i didnt even know this was on, was this day advertised on mallala.com?
Private track days aren't actually public spectating days, and hence are not advertised.
I guess we were a little bit naughty in inviting so many people out (well a couple of invites somehow turned into an entourage - but you get that), and no doubt a few of the drivers who shelled out big bucks were a little bit miffed there were so many gawkers in their way about the place.
But hey, a bit of hype over the first track day of the 1st street legal R35GTR is not entirely a bad thing.
I noticed Martin take some shots of us vultures surrounding the R35GTR when we got there, that will no doubt make the pages of HPI sooner or later :) It was a bit of an excited throng of Nissan lovers .... and with good reason - that car is HOT!
Hey Michael, do you know what times Steve got out of the 35GTR? I had to leave half way through his session :( And yes, I agree - your car looked (and sounded) pure porn out there Michael :rofl:
I was really hoping to make it out there.
Too much drinky not enough sleepy fixed that though.
On times, Martin posted this:
1:15.6 as driven there on the stock tyres etc.
Timed using a Performance Box, peak logged speed 213km/h at the braking zone into the northern hairpin
So comparing to some of the other lap records:
Porsche Cup Cars
Matt Coleman (Porsche GT3)
01:11.8 4/08/2002
Saloon Cars
Bruce Heinrich (EA Falcon)
01:20.6 29/06/2002
Improved Production
Adam Allan (Datsun)
01:16.2 22/08/1998
V8 Supercars
Greg Murphy (Commodore)
01:08.1 13/07/1997
Super Touring
Brad Jones (Audi)
01:10.3 19/07/1998
That's pretty damn impressive - enter it into improved production without any improvements! LOL
The R35 would have been much quicker on proper semi-comp rubber, with maybe somewhere around a 1:14.5 to be had on the new Proxes R888 20s that have just been released (time will tell) :)
However, to my knowledge our R35 was the fastest ever factory specification road car to lap Mallala :thumbsup:
Edited by Martin Donnon
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
