Michael, yours sounded tough as out there today! Noticed smoke come from underneath the car under deacceleration/down shifts, I presume power steering fluid dropping on the exhaust?
You're right Luke, it was the power steering fluid.
  • Replies 71
Nice program^^^. How did it create the map of mallala? Through google maps etc or just traced your path? You planning to head out agin soon, definetly want to see this thing in action!
Ryan
Looking at it, I would say it uses GPS tracking technology.
210kph thru the kink? Too bad, just 15kph shy of what my bike can do :banana:
Joeleo - do you mean a trackskill car because i wouldn't put them in the same class as a super v8
210kph thru the kink? Too bad, just 15kph shy of what my bike can do :P
do you always have to compare apples to oranges
like children at a competition,we all know how fast bikes go,this sites called skylines not bikes r us,otherwise a lot of people would have heaps of stuff to say,accidents and all that,keep it constructive,this sites getting worse,we all know who the try hards and posers are,dont stoop to that level guys
Damo ... you've changed man :/
j/k point taken :P I'm just still 'switched on' from the GP weekend.
No bike does 225kmh through the kink......
"no bike" is a pretty big statement.............Rossi or Stoner may have something to say about that on their lightweights ;)
some of these guys below do similar bends on the Isle of Mann at 260kph on one wheel.........unfortunately this guy didn't quite make the bend, ouch!! :/
Isle of Mann bend at 256kph
Ryan
At a guess it made the map with a G sensor, my go kart data logger would do the same thing
"no bike" is a pretty big statement.............Rossi or Stoner may have something to say about that on their lightweights :)
A current spec litre bike will exit the top of turn 3 at around 60km/h and then have 200 metres to accelerate to peak speed before gentle braking or a complete roll off into the kink. There is no such thing as holding a 180-200ps superbike through the kink flat on conventional road tyres, and there are very few that could roll through there at a genuine 230km/h. The more powerful the bike, the more the back straight gets divided into two straights with a bend in the middle :)
Mallala is always the same story. It seems no matter who you speak to, or how slow their lap times are the bike/car car goes into the kink at 180 - 200km/h. Fact is an R35GTR, one of the quickest production cars you can buy, and capable of an 11 second quarter in stock form, fires out of turn 3 with full traction and enters the kink at an ACTUAL 180km/h, absolutely flat to the boards. Data logging like this, rather than a quick glimpse at the speedo, tells the whole story, even if it doesnt sound so cool :O
Edited by Martin Donnon
I think you have a point there given the wheel slip/loss of actual speed but I for one would love u to lend ruby ur tracking kit.... looks hardcore good (certainly looks better than the home made telemetry system im building)
-D
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
