I probably should add that my '33 has a dual core 53mm alloy radiator, 16" thermo' fan and a second smaller fan, a header tank, and one or two other cooling aids.
Just an update for those interested, i have noticed this thread has been a bit quiet of late.
I have sold the 555's and in the process of purchasing SARD 850's (should receive mid next week).
Also purchasing 24psi actuator off a fellow member which i should recieve early next week also.
POD filter has just been bolted back on.
Be interesting to see how it goes holding the 24psi boost with plenty of fuel and air. Adrian will be tuning again.
The sard 850's are bolted in, also replaced the nismo with an intank Bosch 044 (should not need to upgrade fuel system anytime soon). The new actuator has helped hold the boost at 24psi to redline which i'm happy with also.
Couple of minor issues getting sorted yesterday, blocked fuel filter (Ryco=fail) and the copper plugs were struggling with the extra boost. Luckily Adrian had a Genuine fuel filter and iridium plugs on hand (car seems to idle smoother with iridiums also).
After the car was sorted we decided to tune, lets just say i'm more than happy with the end result (grip is an issue).
Next hurdle is to get the power to the ground.
sad news... I finally hit the brick wall with injector size with e85... I ran out at about 365rwkw with Nismo 740cc injectors. Was trying to get it up to 390 - 400 but i could only manage 382rwkw with the mixtures leaning out to .87 at the top end of the dyno run.
I had to empty my tank and fill it with BP98 to get the power at a safe level that i wanted for power cruise - so unfortunatly i will not be running e85 at power cruise.. However i did get a reliable 380rwkw on pump 98 so we are good to go for power cruise.
I would have loved to be able to fly the e85 flag but that brick wall hurt. I was not keen to settle for 360rwkw on 100 duty cycle - I like my engine.
Yes i did check base pressure, there was no room for improvement, my base pressure was at 52psi - was not keen to raise it anymore.
lol. OK.
Not the answer i was looking for though...
I've edited your quote for you
it doesn't matter if you "need" a cat as much as the plod/epa say you look like you have one anyway.
Edited by chrissso
Would be interested to see the E85 (365) map layed over the Pump (380)
Do things start to happen sooner on the E85 tune?
98 does seem to be a bit crisper then e85. But the response is about the same. With E85 there is more room to improve response with the tune cos you can advance the timing more at max torque.
I was running at about 92% injectors with 340rwkw.. i got the car to run 382rwkw with e85 but it was getting leaner and leaner as it reved past 5000rpm - no more fuel left.
For a nice safe e85 tune with 740cc injectors i would say is around 335 - 340rwkw. I wanted more power then this to power cruise so settled to go back to pump where i got 374rwkw on a fat fat tune in case its hot.
yeah the torque was about the same. I did not push e85 too much.. i was more concerned about the fuel issue more then anything. I would rather the engine be running less then 80ish duty with pump 98 with more power instead of running e85 at 100% with less power.
for my car i can safely say that e85 makes less power then BP 98. Because my 740cc injectors are too small.
This make me even happier that I opted for the overkill 910cc Siemens - not that my current exhaust housing/wheel combo' will support 380-400rwkw, but we all know how things usually go :down:
Lee, good luck mate. Stick a top of the range LSD under the rear, get some ET Street Radials on there, dial out as much negative camber on the rear as you can... and it will still struggle. Traction in 4th should be good though.
This make me even happier that I opted for the overkill 910cc Siemens - not that my current exhaust housing/wheel combo' will support 380-400rwkw, but we all know how things usually go :/
yes. If your running e85, think injector size's as big as as you would run when running methanol or close to it because you need very big injectors, i was kidding myself before thinking that 740cc's would be enough for 400rwkw, I just figured it would be enough.. But then the brick wall came and knocked the shit out of me.
This is the way i work though, i never listen to what anyone says I allways have to go there and do it for myself before i learn a lesson or before i learn anything in that matter. I am no text book learner I can only learn something after doing it myself and then i can very easily work out how it was done, what i should have done and how i can improve it.
Can't fault that logic, GT. Full credit to you for doing the hands-on and giving the rest of us very valuable feed back.
yeah cheers mate :/ it costs a bit to do this kinda stuff too.. Dyno's don't come cheap (even though it does not for me but its still money i fork out) I don't know how much longer I will be doing it for...
If it wasnt for my friends who have Dyno's like Wayne @ Hunter All Wheel Dyno & Anthony Collins I would not have done any of this stuff, they are the ones who sponsor me lol ohhh + the Dirt man helps out too these days
Matt,
A Kaaz centre is definately on the cards and i will doing everything possible to straighten my wheels up (has a bit of camber because of the coilovers at the moment even after a wheel alignment). Yeah i think your right about traction in fourth, going to struggle no matter what i do in the first three gears me thinks (especially when the cool air comes).
Did you manage to get the 14th free for westys dyno day mate?
Lee
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
