Dave dont forget, you'll need a shifter like mine to use once the extension is fitted, otherwise changing gears wont feel the same
Feel free to come over and try it out, ive already fitted all 3 extensions to mine - it feels great! It used to be 10mm from gear to gear
you will need to re-tune the car. where are you located? i can suggest a tuner with E85 experience
Yeah I figured that it would need a retune. I'm in Brisbane, but I travel down the gold coast to get Matty Spry from PITS to tune my car. Im just curious if its worth swapping over from toluene to ethanol with a 30% mixture.
PJ I bought a new under car surge tank with two outlets and I already have one 044 sitting in my toolbox itching to go in. Im not too sure if i want to go E85 though as its a pain in the arse up here in QLD to get. I can deal with carrying around a 10l jerry with toluene and filling up 20l and putting in 10 to get that 30% mix. Cant do it if i wanted E85.
Hellooo,
I think i'm going to swap over to a twin scroll single, and e85 and before my engines built i will ask for more comp for e85..
at the moment i have 800cc injectors, a tomei rail and 2 x 044 bosch pumps.. looking for around 500kw or there abouts on my built motor.
270degree cams 11.2mm lift pauter rods, mahle pistons, springs etc will be done..
thinking of the 4088r garrett if i can get it fairly responsive.. or keeping my twins or going to gt-rs twins
what size injectors will i be needing? and anything else i will need, what comp ratio should i ask for?
I have been told by a Motul rep that Chrono 300V is not recommended for engines on ethanol or methanol.
Apparently the Ester in the oil reacts with the ethanol and creates a gluey substance. I have seen this in my catch can.
So ive switched to Turbolight 4100.
If anyone running E85 is interested i can get Royal Purple XPR 10w40 (Racing 41) at a good price if i buy in bulk.
They come in cases of 12 quart(950ml) bottles.
Racing 41 oil is formulated to run in engines on Ethanol and Methanol.
Perfect for all us E85 boys and girls :)
Looking at $350 per case plus delivery.
sweet... but how does this oil go on pulp? i run pulp most of the time atm....
when e85 is more available i'll be installing one of those tiny pc's in the glovey and switching more often
hamish, dude, i'm sure i told you about performancelub.com? he has the XPR - he also told me to try AMSoil, which is also supposedly suited to ethanol/methanol.
XPR i think is a straight Group V oil, so it's tasty stuff indeed... but with Redline price tag though...
Harold does to group buys, i might be keen if there's a bit of interest :D
That is the supplier :D
I reckon we get a group buy going on the XPR oil. Ill be in for a case.
However Harold informed me that the margin on XRP is small so a few cases would have to be bought for there to be a decent discount.
If we can get 5 cases i reckon it would be well worth it.
Just to point out, there is a guy on EBAY selling old stock ACDelco oil filters.
They come in a box of 12 and only $39 Delivered!!!!!!!
I have just snapped a box up, only 3 boxes left.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
