Hey guys anyone know if its ok to run Octane booster with E85 - just for a bit of added protection??
Would it affect AFR or the ethanol content?
No need, you have a world of headroom with e85
WOW Adrian! Good result. Whats your setup again?
cheers Dave
running a 3582 iw with .8 rear, plazmaman plenum, extreme highmount, hybrid cooler, 3 inch dump with seperate gate pipe that merges back into 3 inch half way to cat then 3 inch decat running into 3.5 catback!
got bit lean, that run woulda been holding around 28 psi, spiked to 30, not bad for iw I think.
That was the kind of figure we were shooting for on the dyno the other day.
My cooler, dump or cat is the restriction atm.
390@25psi is still not too bad, but to have 400 is a nice figure :)
I guess you have to stop somewhere, some people run 24 on pump so cant see how a few more on e85 could hurt!
most people are tuning to .85 lambda, works out around 12.5 in unleaded afr's from memory. Lee's (RB25DETS2) I tuned to .80 and it picked up 15+ rwkw going to .85
I wanted the boost capped at 25psi.
AFRs where 11.8
good additude...no point killing it to get a number. Change the set-up and allow the engine to achieve the gain from the improvements made. Although your engine should have no issues running more boost, its understanding what the engine is telling you from the numbers that separates the good tuners from the ones popping engines trying to get an ego boost. Adam is definately one of the good ones. :)
Ive pulled down a big e85 set-up and seen what happens to bearings running them too lean...the thing is they don't ping on e85 like they do on petrol...its more of a vibration that flogs the little ends out and crumbles the big ends up without hearing a thing. This is quite common on methanol engines with a big tune-up in them but the engines are generally built well enough to tolerate it and rebuilt often enough to not cause total engine failure. I recently crewed for one of the top sprintcar teams in qld and spoke to their engine supplier and tuner at length about this. He is of the opinion a lot of people using e85 may end up with an expensive lesson due to a lack of experience and knowledge using this product. These same guys also supply engines to the current champion V8 supercar team so are at the pointy end of e85 engine development in this country...they know their stuff.
Edited by DiRTgarage
yeah it's definately horses for courses, a big dollar engine is too risky to experiment with!, I'm not a big fan of pushing extra timeing with E85, normally 5 degree's more is plenty, anymore and you can feel that vibration your talking about, the engine note changes and sounds very angry, if your after a dyno number I cant see the harm pushing it for once off, my engine is what I call a throw away, it's taken 30,ooo kms of punishment on e85 if she pops I'm prepared to get another low k's engine and start all over!
As for stupercars they should be forced to have a controlled afr, the big teams with the big bucks can lean there engine's much more than a team on the fringe, they must be running crazy afr's there melting there boots in the car and getting sensational milage, I'm sure the rule makers are dissapointed that the E85 didnt change the stradegy as much as they hoped for !!!!
Can you guys confirm if E85 meets this definition? At the moment I think not due to the number of sites:
Pump Fuel: A commercial fuel (as defined above) available for sale on demand from a roadside retail bowser
outlet at each of at least five separate service stations in each of at least three Australian States.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
