Alright guys.
A recent topic: http://www.skylinesaustralia.com/forums/Tuned-1002hp-R34-T88-t237291.html has got me thinking.... How much power can you milk from an RB engine?
I'd like to hear from others who have recent links to workshops or personal projects that state with proof their hp/kw ratings.
All RB's are up for discussion. 20's 25's 26's and strokers.
I have heard rumous of 1500hp monsters :banana:, but I've been unable to verify the fact.
It would be interesting to see what the greatest are using.
https://www.sau.com.au/forums/topic/239295-heaviest-hitting-skylines/
Project GTSt by GTaRT Racing in the UK.
RB25DET with T51R and all the fruit. Has run a low 9.
http://au.youtube.com/watch?v=u6qqmIjYc-I
Actually that car is an RB26DET with a T62R and run a high 7 now :O
Heat Treatments are the most powerful I know of, "over 1200hp"... has run over 190mph on the 1/4 mile. Considering there are ">1000hp" GTRs which have only cracked 160mph, it must be making a fair bunch.
Are you sure you are not getting confused with the American version Project GTST?
Some other performance company in the US also has a project GTST which has run a 7.
UK car is black.
US car is silver.
UK car is black.
US car is silver.
I am 110% sure. Check this link, and on that page you'll see links for the progress of each year - you'll find you are thinking of the same car and that it has just had huge progress over the last couple of years. John went from GTArt to Abbey Motorsport and from RB25 to 26 when things started getting really serious:http://projectgtst.com/index06.php
Edited by Lithium
Certainly has come along way! Why does everyone jump on the 26 bandwagon lol
In its form as a 25 did they think that is all they could squeeze out of it?
EDIT: Maybe i should swap my GT3076 for a GT3582 lol
Milking usable power and milking 10000RPM Power are two things.
Turn boost up to 2.5 Bar...get it on a dyno...add racing fuel and presto, you either have a
blown engine.....or you get a 1000+horse power figure.
Most of the vehicles you are talking about get a re-build straight after their run.
Not many here want to see if there motor will handle that sort of punishment :kiss:
  • 3 weeks later...
I'm not convinced they gave the 25 a chance, they blew one up but I don't think it was a 25 limitation so much as oil flow and they may (not 100% so don't hold me to this) have had issues with the first 26s until they sorted it out.
GT3582Rs are an aweful lot of fun on 25s! GT30R is definitely more punchy, but above 4000rpm a GT35R starts becoming rather nuts - 20+psi and you're looking at a car capable of into the 10s with the right setup. Huge fun! But no traction on the road.
I won't post anything other than to highlight my favourite bits of your post. :P
Oh yeah, Heat Treatments GTR will be tuned in a matter of days with its latest changes - I don't know if they'll make the figures public or not but if any indication is given I will post it. I suspect if RIPS maintains his madness and pulls it all off we may well see a new worlds fastest RB powered drag car record.....
Hahahaha nice, liking it so far - then? :O
I wonder what makes more power given equal displacement... the 2J or the RB? Guess all one would have to do there is bench flow the heads against each other really.
one thing is for sure. the RB is the fastest LOOKING motor ever made. its like Nissan windtunnel tested that thing, and the 34 rocker covers have a nicer finish than most people's cars.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
