So I've recently replaced my old HKS 2530'S with the GARRETT 2860'S-5. I was instantly impressed with the low down power. I'm still trying to convert the speed into RPM to get a direct comparison. Because the shop that did the power run with the garrett's was a V8 place they didnt realise the RPM limit, getting off it at around 7,000rpm in 4th opposed to 8,200rpm so the run was never complete.
Now, they were different dyno's but I've had my car on both previously making nearly the same power. But needless to say these GARRETT turbo's are good bang for buck. On the garrett run we had major issues with wheel spin, seen in the dyno also.
HKS 2530'S made 21PSI at 5300
GARRETT 2860'S made 20PSI at 4,300
Edited by monga
https://www.sau.com.au/forums/topic/239481-garrett-2860-5-v-hks-2530s/
Can you get it on the same dyno? Just from the corrections you can see a number of differences
IT Temp - 52degree vs 23 (which will affect outright power signifigantly)
Shoot6F vs Shoot6
And the list goes on :happy:
That first graph though, the 2530's come on pretty late :banana:
Have you changed anything other than the turbos??? Like cam gears, cams, tune etc?
I ask as the 2530's arent making 320rwkw till 5800rpm so there was definately something 'up' with the 2530 run. They should be markedly more responsive than that.
Change nothing, just took those turbo's off then replaced them with new ones. The two dyno's make very similar power, as I've compared in the past. Regardless its a tuning tool and turbo's worth just over 2k are good value.
What mods are done to your car?
And it might be good to get another dyno done showing RPM. Might be worth it since you have gone to this length of trouble.
IMO the biggest difference between hks 2530 and the -5 is that HKS changes the inside of their housing which allows more airm gives slower spool up time but more top end if that makes sense.
R32 GTR's do 28.5 km/h per 1000rpm in fourth.
Oh there is no dbout price vs effectiveness the garretts win hands down, totally agree there.
Im just @ a loss as to your 2530 response (or lack there of), its very sub-standard where they should be much closer to the -5's response :banana:
240rwkw @ 5000rpm is no good for the 2530!
Do you have cam gears?
Maybe the 2530's like a different setting to the -5's perhaps? (just thinking what could be the cause)
No cam gears dude.
I think the 2530's are reasonable, here is Jonn's dyno with the 2.8 stroker with the same sort of power line locally here also.
I think the 2530's would handle more boost and rpm, the 2860's feel awesome for the track ect.
http://www.skylinesaustralia.com/forums/in...st&id=15204
Thats a 2530 graph, and you can see its very similar to your -5's graph give or take a bit which is fair enough.
It was m&m's setup from a couple years ago.
http://www.skylinesaustralia.com/forums/in...t&p=1797201
Its all interesting :(
You've got big cams too dont ya? (was looking @ ur post in RB26 dyno thread)
Cam's are reasonable dude, depends on tune also I guess if we increased the timing the power band could change. I'll hunt around but I've got my garagesauras power run around here somewere and its got bulk timing tuned to 102RON and brings them on much earlier.
generally do the 2530s run out of puff or blow first?
I was thinking 350kw should be achievable from my car with 2530s without too much lag
it was laggy before with the 2530s, exhaust and boost controller, but i was thinking porting, and cam gears should be enough to help avoid this?
I think the 2860's will run out of puff before the 2530's, which technically will make more outright and topend power. 350kw is achievable wth both.
Depends what you call lag, if your happy with power around 4,500-5,000rpm you should be fine.
Few graphs from here on the West.
Great graph...would have loved to see -7's and -9's plotted as well.
2530's and -5's improve response with a good set of Cams.
GT-RS can only improve with a larger displacement.
Interesting graph comparo Brockaz, some setups have given interesting results!
Actually Brockaz - do you have Gav's graph with the new turbos on it to stick into that?
It would be something to drool over :banana:
im about to install a set of -5's on my gtr in the next week or so, waiting for them to come in as they are out of stock.. will post my graph as soon as its dynoed.. our goal is the low to mid 300kw at all 4s mark
from what i have heard, definately great bank for buck with the garretts
I only have one of his preliminary tunes.
I'll see if I can get a copy of his latest graph, which shows the -5's with roughly the same top end as the GT-RS's but with the massive midrange.
I can probably get a copy of a set of GT-SS's running abour 460hp to compare as well, so I've kept all the data and will add to it when I get the chance.
Oh, and the 2.8L of John's with the 2530's is running roughly 20psi.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
