With the price of these cars coming way way down, shold see a rise in popularity! For me the fact that the rb25+box is factory fitted, with better brakes etc stronger drive line makes it an appealing package if u can pick up a cheap one. My sedan is slowly getting there, few more suspension bits needed to make it handle better.... but all cars, r32, all the s chassis etc need suspenension mods to be where most owners want them! :down:
Yeah you have to wonder really. Theres a misguided perception that they're heavier but in reality the difference is a massive 50kg (1370kg vs 1320kg); wow, 3.75% heavier. R33 is stiffer, wider, has a better motor, stronger gearbox, bigger brakes, more power, more torque... All on basically the same suspension layout which works fine for R32s. So given that a usable s1 is often cheaper than the now overpriced R32s, its weird you don't see more.
Only reason I can think of is that plenty of 'drifters' are more into what is trendy.
Edited by floody
Yep, those where the day's.... now it sits in the garage, never driven... it is a terrible shame that I'll have to set right by christmas...
I found some fotage of it before I smashed it the first time.... Oran park... so decent angle out of the old girl... and a good bit of inspiration.
But PLEEEEEAAAAAAAAAAAAASSSSSSSSSSSSSSSSSSSSEEEEEEEEEEEEEEEEEEEEEEEEEEE don't tell the missus I won't to get it going again...
I know this is an old post but thought i might throw in some info for people looking.
My team mate had a street tuned R33 last year and it was grate fun to drive. i drove it both on the street and on track and i liked it.
if you are an Average australian built bloke or bigger you may find it much more comfy over the s13 and r32s.
i currently have a R32 and it has a rb25 and gearbox in it but i was neally contemplating swapping it for this year with my team mate as i loved it so much.
A few facts. they have the same steering rack as an S14 which is rumored to have more lock than other nissans (this is false. as we compared S14 to other nissans) so even without the lock spacers that i had in my r32 the r33 had more lock.
The front suspension setup is far more advanced that that of the r32. the geometry of the front end can allow you to achieve a lot more grip.
The rear sub frame is the same or be it similar to S14 and R34 which offers far more grip than the R32.
The car we had ran a hiflow turbo which is by far the worst thing you can ever do to one. it was lagy then it dropped power off far to much. a HKS2530 would be ideal for tight stuff and learning as they come on so strong but they are limited to around 230rwkw. somthing out of the new GT30 series of garrets would be ideal once you had the basics. a friend of mine has a GT30 somthing on a rb25 in r32 and it is pretty off tap.
oh then RB25 engines can produce a safe 260rwkw and with forgies the sky is the limit. or 300 rwkw.
the gearbox is tuff as funk. i flat shift with mine both during drift and circuit.
the diff ect is good but they really need a good LSD as we had endless problems with shimming the stock diff.
and the hand brake is a let down. once a gain we had issues there and all that was needed then was hydro hand brake.
so once you have spent a year or so involved with drifting and taking to top level drifters you will learn that the things that an r33 has on it will be a massive advantage.
But i i was going to get another drift car i would get a S14 as they have so much after market support ist not funny.
Dan,
plz post pics and vids of your r33 in action pls!
I'll see what I can find around the place.
Might take a little while though, I have a fair bit on atm.
DJRIFT makes many good points. Including the last one :)
we had a few R33's at the VIC Drift Champs at Winton last weekend.
R32BigBoy's pics from the day are here:
http://pa.photoshelter.com/c/jrmphotograph...000jAD.zi1Ck0k/
  • 1 month later...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
