Full synthetic on bottles today dosent mean 'full synthetic' needs to say 100% synthetic
motul chrono 300v is a grade 5 oil = aircraft or jet grade
motul 8100 excess is blended grade 5 and 4 = best value for money
something like castrol edge is grade 3 and u pay way to much for it.
I switched from 300v = bout 150bux to 8100x-cess which is 80bux; considering i do an oil change every 2000kms i make quite a saving lolz.
  • Replies 43
interesting.. i was thinking about running 8100 in my car when i run the car in low power mode, but low power is 340rwkw so maybe i should wait till i put a lower wg spring in.
Kinda sucks huh mate that companies can write 'full synthetic' and it dosent even need to be; just a blend.
The info on the grades are correct though:
grade 1 - mineral
grade 2 - blended 'fake' sythetic with mineral (castrol magnatec fits in here)
grade 3 - better quality synthetic ( castrol edge and mobil1)
grade 4 - higher quality
grade V - jet grade 100%ester ( 300v and redline oils fit in here)
Thats why i think 8100 is fantastic cos its blended highest grades which is still better than something like castrol edge.
its 5w40 as well; 10w40 is a bit too thick for an rb26 with stockish compression.
In terms of which viscosity of oil to use I think it will be a case of trial and error as this will depend on your bearing clearances, and will vary from engine to engine and will also depend on your oil pump flow and pressure.
My case in point.....I used Mobil 1 5/50 in my stock sr20. Oil pressure is fine and doesn't drop off at idle even after 30 laps around Barbagello. My brothers LS2 we tried the same Mobil 1 and it had shocking oil pressure at idle after giving it a hard time. Switch it to Castrol Edge 10/60 and oil pressure is perfect. Generally, there is not much variance in max oil pressure (probably due to the oil pressure relief valve) but it is at idle after giving the car a hard time when the viscosity is noticeable and oil pressure may become marginal.
Incidently, I just pulled down my SR with 40,000 klms which has done 100's of laps around Barbagello and the bearings were still like brand new using Mobil 1. I was going to try Motul 300v in my new build (after run in) but I am now considering staying with Mobil 1 given the excellent condition of the bearings given the flogging it has had.
Edited by juggernaut1
Royal Purple is very good oil.. on par with the Motul. I run the RP10/40 in my forged engine no worries. As already said though, your engine builder should know what oil best suits your application.
Actually the Royal purple is a great oil but more on par with motul 8100. 300v is a clear step up in terms of ester content. Hence it is a lot more expensive.
i have just rebuilt my engine with acl 87mm pistons, tomei cams etc
what first oil should i put threw the motor? motul 10w40 synthetic? is this right?
Woah definitely not... Check with your engine builder but chances are he is going to tell you to run a mineral oil. Reason being is that he wants the rings to bed in. This won't happen very well with a fully synthetic oil and the engine will burn oil badly for the rest of its life.
Edited by nfi
A friend of mine who's spent a lot of his life as a mechanic working on bikes has tainted views on Motul oil , he does agree that the highest spec synthetic is good but wouldn't touch any of the rest of their range .
He mentioned that they market aggressively and sell on price . Read into that what you like .
His thoughts on synthetic oil pretty much start and end with Mobil 1 and in the case of hard worked bike engines he suggests Mobil 1 Racing 4T 15W50 . He mentioned that HRT uses it and at times they used to snag supplies of this oil going to bike shops who ordered it . You find it in 1 and 4 litre bottles which is a pain but some bike shops get it in 205L drums .
Whatever you use should be based on clearances and temperature range IMO .
A .
There are three oils i have used over the years that I wouuld not hesitate to use again. Motul chrono 300v. Redline, And Royal Purple. All have proven to offer good protection in extreme situations such as track, drag etc.
I have no particular favorite, rather more a case of what is available at the time.
They are all 100% synthetic and on teardown inspections have all performed admirably.
Some mechanics are total clueless asscracks if you ask me.
The head mechanic at landrover told me that the oil they use in my mothers discovery is castrol magnatech and costs 200dollars for 5 litres to which i replied "magnatec is only about 30dollars"
he replied "oh its renamed, its actually called castrol edge" (hmmm still only 70bux at autobarn)
Majority of mechanics know dick when it comes to......well 'anything'
Stealership!!!!!!!
Stealership!!!!!!!
lol
what i have noticed from the change engine is quieter ,oil temp down, oil presser down ,and after a dyno day today castrol made 304kw & R/P 309kw so i don't think that's to bad but i will try a 15/50 next.
Edited by WARLORD
lol
15 cold weight is waaaaaay to thick for the turbo; in past i tried to run it and on coldstart you can hear a metal grinding in the turbo.
definitely no thicker than 10; actually make that 5w40-60
just a quick question?
for example 15w50
does it run 50w when cold and 15w when hot? or vice versa?
im running the 5w30 castrol edge stuff and my oil pressure is horrible and its only 1200kms old.
use to just run HPR10 and oil pressure was fine.
Edited by l0WRB
Stealership!!!!!!!
You mean dealership mechanics right?
grade 1 - mineral
So the base stock of 300v is ester (or somwhat a variation of it)? From what I've read, ester is only used as an additive for blend with the base stock, so is the base stock of 300v is still PAOs (Polyalphaolefins)?
royal purple and motul 300v is around that price as well.
I think i'll stick with royal purple. Could someone confirm how long does 300v needs to be changed? I heard it dosen't last as long since its a race oil.
BTW, sticking to the topic title. I believe Royal Purple makes a run in oil (on the US website). Might be a bit hard to get it in Australia.
Edited by __PhaseShiftDown
Compared to Castrol Edge 10-60 I found I got 6 months out of the 300v instead of 3 months with the Castrol. This was based on periodic oil anaylsis tests, the Motul retained its viscosity better in my engine. I also get no cold start noises from the Motul unlike the Castrol.
Johnny - I disagree 15w is too thick for a turbo, if you heard metal grinding on the turbo like you posted I'd say it';s a fair chance you had stuffed turbo bearings that would not be caused by the weight of the oil (cheap oil maybe?). I have run a 300V 15W-50 thru my pair of HKS 2530s for 5 years and they are both in perfect working order.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
